Idle question?
Old Apr 1, 2009 | 08:14 AM
95SiPrelude's Avatar
New User
Default Idle question?
I just bought a 95 prelude si, it runs and drives perfectly but when i start it up in the morning the idle sits at about 1,500rpms. Most of my previous cars on a cold start would sit at a perfect idle (about 800rpms). Would this possibly be a idle air controller problem?
Old Apr 1, 2009 | 09:34 AM
mattsnooz's Avatar
Default Re: Idle question?
its suppose to idle at 1500 upon cold start. After it warms up to nominal operating temps the idle should drop to approx 800
Old Apr 2, 2009 | 05:31 PM
duanes's Avatar
I second the answer - When the engine is completely cold, you will have 1200-1600 idle. The colder the ambient temp, the higher the RPM.
The Cold air valve is a piece of temperature sensitive "wax" that expands as it warms. There is a small (3/8" or so) hot water line from the engine, so after a pretty short time, the valve will start warming and the idle will begin to drop to normal running level.
98-blackhatch
Dec 5, 2014 06:27 AM
95Sedan
Oct 11, 2013 03:29 PM
DFW
Sep 29, 2007 09:07 AM
wickedxboi
Nov 9, 2002 12:39 PM
RR98DX
May 9, 2002 04:46 PM
