hydro lock
Old Feb 23, 2003 | 01:46 PM
SleepY2112's Avatar
Default hydro lock
well a friend of mine recently hydrolocked his car and now he's wondering what he can do? any and all help would really be appreciated.
Old Feb 23, 2003 | 01:52 PM
rjr162's Avatar
Default Re: hydro lock (SleepY2112)
don't crank it. Take the spark plugs out and then crank it over. if it's not too late the water will fly out, get new plugs and change your oil and see how things go. If not, time for a rebuild
Old Feb 23, 2003 | 02:34 PM
LUVJDMH22's Avatar
Default Re: hydro lock (rjr162)
Once its hydrolocked it will never be the same motor again. Getting enough water to hydrolock it means that something inside is going to be messed up for sure. A rod will be bent more than likely and if not bent then totally broke. I hrydolocked my old H23 and threw a rod out the back of the block. He can drain the motor and get new plugs and everything, it should run if something isnt totally broke inside. But as soon as he runs it hard its gonna break the rod. One will difentally be bent no matter what. He can do what I did, make an insurance claim and get about 2-3 grand. Then get an JDM H22 swap. If i were him i would try to drain it first though, thats what I did, it started up and then it ideled all crazy, then went BOOM!!!!!!!!( seriously sounded like a cannon or something) which was the sound of a rod making about a 3 inch hole in a honda block. Good luck to him
Old Feb 23, 2003 | 05:18 PM
LudeyKrus's Avatar
Default Re: hydro lock (LUVJDMH22)
Your motor prob. blew b/c you didn't pull the plugs before trying to crank it. My bud w/ a 240 and AEM CAI hydrolocked his car bad. Kept trying to crank it after it stalled out in a flash flood. Got it towed home, pulled the plugs, drained it, and changed the oil ~4 times and ran it for a few min's each time, and FINALLY got all of the water out. There was roughly 4 gallons of water sucked up! And he pushes that car fairly hard and often and has had no problems since, so your car MAY be completely fine!
[Modified by LudeyKrus, 9:19 PM 2/23/2003]
Old Feb 23, 2003 | 07:19 PM
LUVJDMH22's Avatar
Default Re: hydro lock (LudeyKrus)
We actaully did remove the plugs first. I garuntee your friends 240 has a bent rod somewhere in there. It can still run perfectly fine. But for the most part, when you hydro lock a motor is gone.
Old Feb 23, 2003 | 07:31 PM
LudeyKrus's Avatar
ummmm.......sorry you blew your motor dude, and yeah, there's a good chance of seriously screwing your motor up when it hydrolocks, but I guarantee you that you're wrong. It's very possible to not blow your motor.
Old Feb 24, 2003 | 12:12 PM
LUVJDMH22's Avatar
Dude. I said for the most part, or more than likely when you hydrolock your motor is blown. Sure its possible to not blow it, but when you suck up that much water it usually is blown or is gonn have serious problems.
Old Feb 24, 2003 | 03:24 PM
LudeyKrus's Avatar
Oh really? And we've torn the block down and the internals are fine. Yes, there's a good chance SOMETHING may break, but there's also a significant chance that just draining the oil a few times will fix it.
[Modified by LudeyKrus, 7:25 PM 2/24/2003]
EF8DayDreamer
Jan 18, 2012 10:12 PM
2hondas_noluck
May 18, 2011 09:13 AM
sw96
14
Nov 8, 2009 11:05 PM
Madrek
22
Jul 20, 2005 05:38 PM
allanonjj
Jun 9, 2005 03:23 PM
