HP estimate
How much whp do you think I will make? Here is my setup currently. I plan to add the turbo after I break in the motor.
h22a
Port n polish head
Ferrea springs, retainers, valves
3 angle valve job
Skunk 2 intake manifold
68mm throttle body
Sleeved block
arias 8.4:1 pistons 87.5mm
eagle rods
AEM ems standalone
stock exhaust
stock cams
h22a
Port n polish head
3 angle valve job
68mm throttle body
Sleeved block
eagle rods
AEM ems standalone
stock exhaust
stock cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude01 »</TD></TR><TR><TD CLASS="quote">How much whp do you think I will make? Here is my setup currently. I plan to add the turbo after I break in the motor.
h22a
Port n polish head
3 angle valve job
68mm throttle body
Sleeved block
eagle rods
AEM ems standalone
stock exhaust
stock cams</TD></TR></TABLE>
D'oh.
You're going to get a turbo-back once you get your turbo right? Just making sure
btw, sounds like a very nice build. How much boost do you plan on pushing?
h22a
Port n polish head
3 angle valve job
68mm throttle body
Sleeved block
eagle rods
AEM ems standalone
stock exhaust
D'oh.
I rather play it safe. I spent a lot on the build. I want to make sure the motor is healthy before slappin the turbo in. I plan to run a garett gt3040r turbo and will start at 8psi. With the low compression I'm sure I can up the boost higher.
h22a
Port n polish head
3 angle valve job
68mm throttle body
Sleeved block
eagle rods
AEM ems standalone
stock exhaust
stock cams
depending on the tuner you need a guy that knows aem or it will be very difficult. If your tuner doesn't know it... get hondata
h22a
Port n polish head
3 angle valve job
68mm throttle body
Sleeved block
eagle rods
AEM ems standalone
stock exhaust
stock cams
DISMANTLERGSR
59
Jan 12, 2004 10:55 AM
