how much for engine swap?
Ummm how about everyshop is different you guys are going to have to <U>CALL</U> different shops and shop around conpair prices and go where you think it best for what your looking for......
Engine hoist, jack stands, a jack, metric wrenches,rachets,1/4 drvie sockets,3/8 drive sockets, 1/2 drive sockets, deepwell and shallow as needed, assortment of screw drivers, phillips, flatheads, prybars, shop manual( will save much time and $). Dvom.
I did my engine swap, auto to manual conversion in my driveway. Before you install new engine do t-belt, balance shaft belt, water pump, balance shaft seal retainer, clutch
is needed.
is needed.
How much work to hook up the old tranny to the new engine? I have a brand new clutch. Not to steal your thread, but w/ 150,000mi should I just replace the tranny too?
Thanks
matt
Thanks
matt
Just to give you a idea on prices , it can range from $700-1200 depending on the shop and thats just to swap the motor out and if you get another motor it will run atleast $2300 +. Why dont you just have the motor fully built and go from there . With sleeves and rods/pistons/bearings and water pump/ timing belt it will run about 3k for a motor that will make tons of power if you go n.a. or f.i.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M@ »</TD></TR><TR><TD CLASS="quote">How much work to hook up the old tranny to the new engine? I have a brand new clutch. Not to steal your thread, but w/ 150,000mi should I just replace the tranny too?
Thanks
matt</TD></TR></TABLE>
I see you're in Lawerence KS.
I will do it for you if you want to bring your car to Kansas City.
We can discuss prices if you want to shoot me a pm.
Thanks
FrederickRighteous
Jan 24, 2009 07:08 PM
........The engine swap is pretty straightforward
