HOW TO: Ignition Key Light
Old Jun 24, 2008 | 08:13 PM
lude_lover's Avatar
Default HOW TO: Ignition Key Light
Not responsible for any damage while attempting this.
Things needed
-screwdriver
-Soldering Iron/solder
-heat shrink
-about 6ft of wire total
-wire tap
-new plastic piece and the wires leading to the light plug
So the majority of preludes have this option standard, but im pretty sure that majority, if not all of, the "s" model preludes dont come with the ignition key light which goes along with the spaceship coolness. I wanted this as well so I looked into it. It was extremely simple to do.
Start by disconnecting the negative battery terminal. Remove the screws to panels for the underdash panel, steering colum panel, and shifter console.
Here is what it looked like without the light(my old setup)
After pulling off that black piece(just slids/snaps off) this is what your left with
Next. Locate a lighted ignition switch at a junkyard. Costs less then $10 for it all.
This little white plastic will be removed and put on your car. It just snaps off your ignition. Notice where the light goes in too.
Next is just wiring it, I ran a tap off the cigarette ligher so its not on all the time, just when your ignition is on. The wire you tap off is Either White/red or White/blue. It changes colors after the connector under the radio but either one is what you tap off
I soldered the wires together and heat shrinked it. Ziptie for a cleaner end product
End product :D Its brighter on one side but the picture doesnt show that it does go all the way around in a ring
Old Jun 24, 2008 | 10:22 PM
russlan44's Avatar
Default Re: HOW TO: Ignition Key Light (lude_lover)
good write up just tell OP what gen is it for
Old Jun 25, 2008 | 04:45 AM
prelude_h22vtec's Avatar
my car def already has that
Old Jun 25, 2008 | 08:16 AM
lude_lover's Avatar
Default Re: HOW TO: Ignition Key Light (russlan44)
4th Gen FTW
Old Jun 25, 2008 | 12:14 PM
jzobie1's Avatar
Being that it is to show you where to put the key, shouldn't it be wired into something else? I am not sure where it is normally wired to but mine stays lit for 30 seconds or so after I open my door so when I shut the door it stays on. Other than that cool writeup.
Old Jun 25, 2008 | 01:21 PM
Televator's Avatar
Default Re: HOW TO: Ignition Key Light (jzobie1)
For a car with so many lit up gauges, it gets pretty damn dark in there. I wish the under dash lights were also standard.
Old Jun 25, 2008 | 04:19 PM
russlan44's Avatar
Default Re: HOW TO: Ignition Key Light (Televator)
my ignition key light works sometimes which is weared, sometimes it wants to work and sometimes it wont, and after it got broked in it was rare for it to even turn on.
Old Jun 25, 2008 | 09:36 PM
lude_lover's Avatar
Yeah its supposed to connected thru the integrated control unit but its hard to get to being behind the underdash f/b
Old Jun 26, 2008 | 01:47 PM
jzobie1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude_lover &raquo;</TD></TR><TR><TD CLASS="quote">Yeah its supposed to connected thru the integrated control unit but its hard to get to being behind the underdash f/b</TD></TR></TABLE>
Oh ok I see, I didnt know that some ludes didnt come with them. I never fully appreciated it until I just found out that some of you dont have one ha ha
luis_ej8
Honda Fit
Jan 8, 2024 11:12 AM
JohnKam
Oct 8, 2017 04:50 AM
Smok3o3
Feb 22, 2011 05:53 PM
fastfu
Nov 14, 2005 04:31 AM
SaberSix
Acura TL, RL & ZDX
Jul 9, 2004 02:41 PM
