How to adjust TPS...
Old Feb 16, 2003 | 02:31 PM
ludedudesi's Avatar
Default How to adjust TPS...
Ok my idle has been messed up for a while. some guy said it was the tps and i was wandering how you go about adjusting it. And can you buy one from the dealer without having to buy the whole TB. thanks
Old Feb 16, 2003 | 03:44 PM
Cottonwoodz's Avatar
Default Re: How to adjust TPS... (ludedudesi)
No, and you cant...Unless you have a JDM TB..
Old Feb 16, 2003 | 05:10 PM
ludedudesi's Avatar
Default Re: How to adjust TPS... (Cottonwoodz)
Well i swapped my h23 for a jdm h22 so i do have a jdm TB.
Old Feb 16, 2003 | 05:43 PM
rjr162's Avatar
oh, and did you get the note about the TPS? Don't forget to use the new cover sheet....
Old Feb 16, 2003 | 07:20 PM
satan_srv's Avatar
Default Re: How to adjust TPS... (rjr162)
take a dremel and cut lines into the rivets, then you can unscrew it with a screwdriver.
Old Sep 8, 2004 | 01:43 PM
89sih22a's Avatar
Default Re: How to adjust TPS... (satan_srv)
sorry to bring up a old thread but,
2 questions..so can the u.s tps be adjusted
when adjusting it wich way do i move it ?i can see the tps screw holes is sort of a slot opening
Old Sep 8, 2004 | 03:30 PM
ColinKAccord's Avatar
Default Re: How to adjust TPS... (89sih22a)
youll have to get a voltmeter and read the voltage coming off the middle (red?) wire. not sure which way you turn it, but you should be aiming for .45 volts closed, 4.5 at WOT. every motor is different though, and an improperly calibrated TPS can cause all kinds of funky problems, surging idle ect. you may have to mess with it a bit before you get it just right.
check ebay for a sensor, ~$30
once you slot the rivets, the us one can be adjusted
Old Sep 9, 2004 | 09:40 AM
89sih22a's Avatar
thanks i will try that.when i test it does the car have to be running /
Old Sep 9, 2004 | 10:47 AM
LudeyKrus's Avatar
Are you supposed to adjust the TPS when the motor is hot or cold? The voltages will vary a bit when the car is warmed up....
Old Sep 10, 2004 | 06:13 AM
flyrod's Avatar
Default Re: (LudeyKrus)
The car doesn't have to be running, but the ignition should be on if you are trying to measure voltages. On old sensors there can be "dead" spots in its response, usually just off idle. The sensor is just a variable resistor with a little wiper inside it. With a lot of use the wiper will wear out or wear gaps in the resisitor film. If you have a multimeter with an audio output, you can hook it to the sensor and measure the resistance. Listen for gaps in the resistance response as you move the throttle. You can also do this by watching the readout, or if you have hondata you can log the sensors and look for weirdness that way or set the position using the voltage being displayed there. Temperature should be a minor factor, if at all.
lsjon
Sep 3, 2010 12:07 PM
DCxMagus
May 3, 2007 06:45 AM
vtec92lude
Oct 28, 2004 12:16 AM
kholmes
Oct 12, 2004 06:59 PM
evo
Apr 9, 2002 09:39 PM
