high compression lude motor
Old Dec 24, 2001 | 08:24 AM
T.Werd's Avatar
New User
Default high compression lude motor
I am looking to build my lude motor with 13:1 comp. with a built bottom end and a modified head with Crower cams and all of the other goodies. I am looking to put this car on the street every now and then but it will not be dailydriven. Can I run 13:1 comp. with just MSd 6al ignition, tuned V-afc, and High octane fuel? tahnks for the help
Old Dec 24, 2001 | 11:22 AM
girlRacer's Avatar
Default Re: high compression lude motor (Jonesy69)
You won't be able to run that compression on the street. Especially not with a V-AFC. With a Hondata, you should be okay as you can alter timing.
Old Dec 24, 2001 | 12:16 PM
Mike95lude's Avatar
Default Re: high compression lude motor (10sec.civic)
If I remember correctly JG Luder had that exact compression of 13:1...i believe he ran race gas on the street or a mix of high octane premium and race gas...
Old Dec 24, 2001 | 01:04 PM
prospeed's Avatar
Default Re: high compression lude motor (Mike95lude)
If you run your engine with high octane fuel then u can drive it on the street. With the High octane you will be able to avoid detonation. If you are interested in Hondata I am a dealer for them. With Hondata it will make it alittle easier on your engine becuase of the timing control.
Old Dec 24, 2001 | 07:31 PM
The Punisher's Avatar
Default Re: high compression lude motor (girlRacer)
I disagree with girlRacer. My bro-N-law runs a 13:1 daily on 93 octane and uses a V-AFC. He has a Hybrid Civic, but that doesn't matter. Oh, he runs 12's too. He is going to be looking into a Hondata reprogram soon, but I would check with JG. I am not sure where all his problems came from, but I do know it is possible to have a high comp daily driver as long as everything is put together correctly and somewhat tuned.
On a side note, if you are looking to do this soon. I have 5 buyers for a Golden Eagle Sleeve Groupbuy, and I am looking for a sixth. If you are interested, check my profile and shoot me an email. I can promise you this is a deal you can't beat, and I am not trying to make anything off of it either. Unlike other people I have run into recently for a Golden Eagle Groupbuy.
Evolsport
Jul 17, 2009 12:44 PM
unknown2
Aug 5, 2006 04:41 AM
ALLMOTORJ
Feb 2, 2005 08:57 AM
flip1199
Aug 11, 2004 08:10 PM
BLITZ
Oct 29, 2002 07:59 PM
