Help!! Omg!!
Old Jan 21, 2009 | 04:19 PM
Gunner142's Avatar
Default Help!! Omg!!
I have a 1992 Honda prelude. with the f22a1 engine. and Right now where not getting any spark, and the injectors arent firing.. anyone know why?
Old Jan 21, 2009 | 04:45 PM
PirateMcFred's Avatar
Default Re: Help!! Omg!!
Shot in the dark is that the crank position sensor is dead. You will get more help from people if you offer more information.
Old Jan 21, 2009 | 04:47 PM
Bama420's Avatar
Just remember, always check the simplest thing first. What gives the spark plugs spark? either the coils or the distributor. What gives the coils or distributor spark? The ignitor pack.
Don't over-think your issues.
Old Jan 21, 2009 | 05:06 PM
Gunner142's Avatar
Icon3 Re: Help!! Omg!!
Okay. theres what going on We have 40 psi of fuel. we HAD Spark.. dont anymore dont know why we've replaced Cap roter. Ignitor wiring harness Computer. checked all the relays all fuses. we have 160- 180 of compression. when we had spark the only way we could start it. was By choking the engine and it would start then it would run but it wouldnt run very good, if you floored it it would Die then back fire thru the intake and at around 5500 to 6000 rpm. it would start back firing thru the intake, where completely stumped.. and its starting to get really ANNOYing so if anyone know anything please help me! lol please!
Old Jan 21, 2009 | 05:17 PM
Gunner142's Avatar
and Did the 92 Preludes have a crank position sensor?
Old Jan 21, 2009 | 05:30 PM
FTPPRELUDE's Avatar
i dont think so^
did you try a different ECU
Old Jan 21, 2009 | 05:31 PM
Gunner142's Avatar
yes we did.. we;ve Done Just about every freaking thing we can do lol
Old Jan 21, 2009 | 05:56 PM
mattsnooz's Avatar
when did this start happening? out of the blue?
Has any work been done recently?
If your having spark, you have compression, and you have fuel, than the only thing left is proper timing!
My first guess is a ground some where. Hows the tranny ground?
So anyway though your fuel injectors arn't spraying fuel you mean?
Sounds like you got more than one issue? Have you jumpered your service connector pin to pull up CELs?
Old Jan 21, 2009 | 05:59 PM
Gunner142's Avatar
yeah i have i only get code for TPS. which i replaced i dont know why its still there and yes the fuel is not sparying sorry, and ive never messed with the timing so i dont know how the timing would get out of wack and you can sit there turning it over and there'll be no fuel coming out of the injectors at all not even a drop..
Old Jan 21, 2009 | 06:00 PM
Gunner142's Avatar
where is the tranny ground thats the only one i havent checked
and yes it just started happing out of the blue
Old Jan 21, 2009 | 06:01 PM
Bama420's Avatar
Sounds like timing to me. Clock the cap 180 degrees. Are the F22 interference motors? Check your grounds. For ****-n-giggles, check your coolant temp sensor. Check the connections and the harness on the ignitor. Are your plugs fouling?
Old Jan 21, 2009 | 06:04 PM
mattsnooz's Avatar
tranny ground goes down by your slave cylinder (clutch system). It starts at the negative (black) wire on your battery and sneaks down and onto the bottom front of your tranny.
Old Jan 21, 2009 | 06:05 PM
mattsnooz's Avatar
Your fuel injectors arn't spraying fuel? Pull your plugs and smell them after you tried cranking the car
Old Jan 21, 2009 | 06:13 PM
Bama420's Avatar
Does it have a cat converter hooked up?
Old Jan 21, 2009 | 06:18 PM
Gunner142's Avatar
yes theres a cat, the cylinders are COmpletely dry, i took the intake off and left the injectors and fuel rail on and put a paper towel over all 4 injectors and turned the engine over and after there was Nothing on the towels and ive checked all grounds.. the injectors are not spraying period..
Old Jan 21, 2009 | 06:20 PM
Bama420's Avatar
Do the injectors have a resistor pack?
Old Jan 21, 2009 | 06:21 PM
Gunner142's Avatar
I believe so.. not really sure what that does 100% but it does
Old Jan 21, 2009 | 06:34 PM
mattsnooz's Avatar
I'd apply trigger voltage to the injectors manually and see if you can get them to squirt. If you can than I'd say the ground for your injectors is not secure.
Old Jan 21, 2009 | 06:35 PM
Bama420's Avatar
What it does is takes the higher voltage signal from the ECU and drops the voltage to operate the lower voltage injectors.
Check the ground for the resistor pack. Check the wiring from the resistor to the injectors.
Old Jan 21, 2009 | 06:39 PM
Gunner142's Avatar
how offten do they go bad?
Old Jan 21, 2009 | 07:03 PM
Bama420's Avatar
Not very, but how many times have you heard of a car doing what your's is doing? There's no hurt in trying anything. I'm just making educated guesses. Thinking about previous stumps.
Old Jan 21, 2009 | 07:04 PM
Gunner142's Avatar
lol alot they say.. just not allways the same problem
Old Jan 21, 2009 | 09:41 PM
Gunner142's Avatar
Okay. so on my harness.. theres two Wirers that arent going anywhere... one is Pure Black, the other is Black/red. Do you know if these are both grounds? the black/red I think bolted onto the thermostat Houseing.. But the Pure black idk.. if you got any ideas where it mite go Please lemme know thanks
Lukas
Old Jan 22, 2009 | 06:20 AM
Hawkze_2.3's Avatar
YES! The wire that bolts to the thermostat housing is the ECU ground! You will have to have a good connection there for the ECU to do anything. I'd ground the other one too...
Old Jan 22, 2009 | 06:35 AM
Bama420's Avatar
I have never heard of a Black w/Red being a ground, but the black definitely a ground. Ground it. As for the black w/red hook it up to where it looks like it belongs. I know of a site that has the wiring diagrams for all cars. Let me see if I can find it and I'll post a link.
