Help no reverse gear...
Old Dec 18, 2005 | 10:42 PM
wrx'n you's Avatar
Default Help no reverse gear...
I was going for a cruise earlier and i decided to push my h22. I went from 1st to 2nd fine but i missed 3rd gear. Now my reverse wont go into gear. I dont know if it is because of the missed gear or not. Ususally, my reverse would go in smoothly and easily now its like its jammed or something. All the forward gears seems to feel normal and everything. Someone please help...thanks a ton
Old Dec 18, 2005 | 11:14 PM
BB6racer's Avatar
check the normal things like shift linkage and fluid level. how did you "miss" 3rd? did you go into a different gear, or grind but not go into gear?
Old Dec 19, 2005 | 08:24 AM
wrx'n you's Avatar
i just didnt go into 3rd.
Old Dec 19, 2005 | 08:25 AM
mgags7's Avatar
you may have bent your shift fork slightly when you did that, play around with pushing towards reverse and modulate the clutch and it should come back after a bit of trying
you should have searched, this has been covered already....idi0t
Old Dec 19, 2005 | 09:07 AM
wrx'n you's Avatar
i've tried to sorta jam it into reverse and i heard a bit of grinding so i stopped and now my shifter is stuck. Its not stuckin reverse but its not stuckin neutral, its sorta in the middle... someone please help
Old Dec 19, 2005 | 12:11 PM
mgags7's Avatar
dont be scurred dawg....let the clutch out a little and it will pop out
do all of this with the engine running....
Old Dec 19, 2005 | 01:28 PM
PrecisionH23a's Avatar
Default Re: (mgags7)
I did this before as well. Basically start the car and you have to jam it into gear. It will take you a while and you'll have to play with getting it into place, but if you are lucky it will go into gear.
If you can't get it into gear, you probably bent your reverse fork.
Old Dec 19, 2005 | 06:57 PM
wrx'n you's Avatar
so if my reverse fork is bent then i would have to replace it? how much would that run me?
Old Dec 19, 2005 | 07:17 PM
sohclubkid's Avatar
hmm, sounds like a bent linkage. dont hold me too it tho. my buddy had an rx 7 that got stuck in gear, and it was a bent linkage. give that a try.
Old Dec 19, 2005 | 09:26 PM
RMS's Avatar
RMS
an h/f trans issue i've seen several times is the 5th/reverse slider on the main shaft gets burs on the reverse null syncro side that absolutely denies reverse. had one in a '01 with less than 50k miles. trans was mint other than that issue. not too expensive of a part, but rather a bitch to get to. good luck on this not being your issue hopefully.
Old Dec 19, 2005 | 09:35 PM
wrx'n you's Avatar
Default Re: (RMS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMS &raquo;</TD></TR><TR><TD CLASS="quote">an h/f trans issue i've seen several times is the 5th/reverse slider on the main shaft gets burs on the reverse null syncro side that absolutely denies reverse. had one in a '01 with less than 50k miles. trans was mint other than that issue. not too expensive of a part, but rather a bitch to get to. good luck on this not being your issue hopefully.</TD></TR></TABLE>
so if worst comes to worst i would need either a reverse synchro or a reverse fork?
Old Dec 19, 2005 | 09:57 PM
RMS's Avatar
RMS
the syncro was okay, but the slider was f'd.
Old Dec 20, 2005 | 09:16 PM
wrx'n you's Avatar
Default Re: (RMS)
alright, well i found sorta a temporary fix for this. I tried to put the car in reverse when the car was running. I revved the engine up a little and found that it would go into reverse but it would grind, so i can just put the car in reverse when the motor is off. Then i can just rev a bit while pushing up to get it out of reverse.
Old Dec 20, 2005 | 10:53 PM
RMS's Avatar
RMS
if it drops in reverse easily with the engine off then the slider is okay.
Old Dec 21, 2005 | 08:20 AM
wrx'n you's Avatar
so what could be the problem then?
PsychoSiRex
Honda Civic (2006 - 2015)
Sep 16, 2009 09:15 PM
Evil_Ek
Feb 9, 2006 08:33 AM
vinasity
May 30, 2004 06:49 PM
Understeer
Nov 5, 2002 09:33 AM
b20civic
Sep 8, 2002 11:33 PM
