HELP! Misfire problem
Old Aug 29, 2011 | 03:36 PM
carbonemt's Avatar
Default HELP! Misfire problem
I have a 98 Honda Prelude Base Model. Im having a really difficult time with my car. I can start the car just fine, drive it for about 5 mins and then it will start misfiring really bad and then stall. THEN i have to wait a few hours before I can start it and do it all over again. It started when I was cruising on the freeway. Wasnt racing or pushing it hard.
I have replaced the following:
Fuel Pump
Fuel Filter
Ignition Control Module
Ignition Coil
Distributor Cap and Rotor
No signs/symptoms of a Head Gasket and the engine stays cool.
Please help me! I am going insane.
Old Aug 29, 2011 | 05:59 PM
carbonemt's Avatar
Default Re: HELP! Misfire problem
How can 50 people look at this thread and no one have an idea? I really need to get this figured out soon
Old Aug 29, 2011 | 06:11 PM
H22aCB7Coupe's Avatar
try replacing your spark plugs and wires
Old Aug 29, 2011 | 06:18 PM
Fliptard's Avatar
hopefully you don't have an aftermarket MSD set up? I had one on my h22, and had to keep replacing coils because they are junk.
are you throwing any codes?
Old Aug 29, 2011 | 06:24 PM
pestalince's Avatar
Next time it stalls pull a plug and see if your getting spark.
Old Aug 29, 2011 | 07:43 PM
carbonemt's Avatar
Sorry bout that I replaced the plugs and wires as well. I did pull it while it was stalling and I had spark as well. Whats an MSD?
Old Aug 29, 2011 | 07:44 PM
Fliptard's Avatar
Lol, it's an aftermarket ignition set-up. obvy you don't have it if you don't know what it is :p
But your not throwing any check engine lights?
Old Aug 29, 2011 | 08:01 PM
carbonemt's Avatar
Well i always have a light cuz of my test pipe but im waiting on a friend, if he doesn't flake like usual, to come read the codes for me. My dad says its acting like it has vapor lock but its near impossible because its fuel injected.
Old Aug 29, 2011 | 08:06 PM
Fliptard's Avatar
Get your codes checked and we'll have to go from there.
Old Aug 30, 2011 | 11:42 AM
carbonemt's Avatar
Im waiting on my friend to come pull them for me since I cant get it to a shop to pull the codes. A very simple and easy way to explain the issue is once at operating temp my car acts as if its running out of gas. At which point it bogs, misfires, stalls and wont start again until its cooled
Old Aug 30, 2011 | 02:18 PM
97ludedude's Avatar
maybe main relay or fuel pump? next time it does it check to see if your fuel pump is coming on. if you pull your back seat out you can get to the plug on the pump to see if you are losing voltage to it.
Old Aug 30, 2011 | 04:37 PM
carbonemt's Avatar
hey thanks for replying bro. I have already replaced the fuel pump tho. along with everything mentioned above
Old Aug 30, 2011 | 05:45 PM
Fliptard's Avatar
I wouldn't replace anything and start throwing anymore money into it untill you know what your codes are.
Old Aug 30, 2011 | 08:34 PM
typemismatch's Avatar
Honda owns me
X2
Old Aug 30, 2011 | 08:51 PM
carbonemt's Avatar
I figured it out. Ran the codes and it came back as TDC intermittent. So basically its my crank position sensor or my timing is off by a tooth. Ill check it out tomorrow but theres no reason it should have jumped/. Thx
michaelb15
Dec 6, 2012 01:42 PM
egluism33
May 25, 2008 06:17 PM
BadBeck
Dec 11, 2003 05:59 PM
incertitude
15
Nov 18, 2003 11:15 PM
widecoupe
May 12, 2002 11:26 AM
