help on h22 swap problem
Old Feb 16, 2004 | 10:47 PM
eg:R's Avatar
Default help on h22 swap problem
i have a problem with my 90-93 accord intermedia shaft, the shaft does not bolt on to the back of the block, the bolt pattern seem to be difference, anyone know that is wrong here?? this is a 97up sh h22, can i also fit a 93-96 h22 tranny to this engine?
Old Feb 16, 2004 | 11:08 PM
Eddiebx's Avatar
your problem is that you have a SH block, they are different and have a differnt bolt pattern than the other blocks, your gonna have to rig up an adaptor braket to bolt the intermeidate shaft on
Old Feb 17, 2004 | 09:00 AM
PirateMcFred's Avatar
Default Re: help on h22 swap problem (jacklee)
^^^^ What he said...good luck...
the Pirate
Modified by PirateMcFred at 2:17 PM 2/17/2004
Old Feb 17, 2004 | 02:07 PM
Behan's Avatar
Default Re: help on h22 swap problem (PirateMcFred)
http://ian.clendaniel.net/gallery/noatts
Old Feb 18, 2004 | 10:58 AM
spoonhatchblack's Avatar
I'm having the same problems w/the 90-93 accord intermediate shaft also.
H22A4 sh
Old Feb 18, 2004 | 06:08 PM
jdmlude_dude's Avatar
Default Re: (spoonhatchblack)
the SH block has no half shaft...it uses the ATTS box as a half shaft. you can custom make an adapter.
***93 lude w/jdm h22***
Old Feb 19, 2004 | 07:03 AM
Here is more infro pertaining to your project:
https://honda-tech.com/zerothread?id=762014
1slowcrx
Feb 27, 2015 05:06 PM
90lst
Jun 25, 2010 08:06 PM
krazycivicTDOT
Mar 12, 2007 06:44 AM
EGhatch22
Dec 29, 2004 04:54 AM
mad si
May 20, 2003 03:26 AM
