headlight adjustment question
it's in the manual... but if you don't have that you have to look on the headlight itself onece the hood is opened to see the vertical bubble level...
then on the back of the headlight are two plastic screws that look kinda like gears... the top one is for vertical and the bottom one is for horizontal... you will prob need a phillips screwdriver to move the screws around.
hope that helps.
hope that helps.
