header question????
Old Jan 9, 2003 | 10:17 PM
hondaZvic's Avatar
Default header question????
what are the differences in prelude vtec headers from the years 93-96 applications to 97-01 applications?? i know the 93-96 applications have a little bit longer outlet on them, but is that all? and does anyone know the how much longer the 93-96 prelude header is than the 97-01?
thanks
Old Jan 10, 2003 | 03:51 AM
KGAccord's Avatar
Default Re: header question???? (hondaZvic)
why does it matter? you have to chop up the exhuast anyways to fit it. may as well buy the Greddy header though.
Old Jan 10, 2003 | 04:51 AM
aklucsarits's Avatar
New User
I would say that the 93-96 header is more restrictive, and the 97+ is freer flowing. The 93-96 VTECs seem to gain considerably more from a DC Sports header. Meanwhile, the 97-01 Preludes gain very little from the same DC Sports header design.
Andrew
Old Jan 10, 2003 | 05:42 AM
R@mon's Avatar
Default Re: header question???? (aklucsarits)
Andrew
couldnt that be contributed to obd2 also? i dont know im jut guessing. i have a h22a4 in my 4th gen and the header was definately too short...
Old Jan 10, 2003 | 07:02 AM
KGAccord's Avatar
Default Re: header question???? (93h22a4)
hmm I assumed he was talking aftermarket, but if you want oem go for a jdm header from a 92-96.
Old Jan 10, 2003 | 11:45 AM
LOGAN528's Avatar
this may help it may not. the new import tuner does a 97 vtec type sh in its power pages. and they discuss installing a header from a 93-96 vtec motor. its a greddy header and it comes in 2 peices. whether the type sh is drastically different from the non they didnt say. but in the sh applcation the had to modify the mounting brackets on the secondary pipe to fit the type sh oil pan configuration. hope this helps.
Old Jan 10, 2003 | 12:44 PM
hondaZvic's Avatar
Default Re: header question???? (LOGAN528)
i am talking about after market.. and i wanted to know for this reason: i have a h22a4 in my civic.
if i buy a header for the 97-01 it will bolt up to everything the way i have it now. ex:i have a gutted cat on my stock exhaust manifold.
but i was thinking since the 93-96 headers are longer, that maybe if i bought one of those i could eliminate my cat.... maybe? maybe not?...just sort of have header to exhaust pipe and no cat. but if the 93-96 is not long enough then i will just get a 97-01 application.
Old Jan 10, 2003 | 01:39 PM
Shakes's Avatar
space cadet
if you want to eliminate your cat, then run a test pipe. its just a straight through pipe and will cause a loss in torque, make it much louder, and gains in HP. have one custom made for your hybrid and you should be good to go.
flashmang
Sep 5, 2004 12:38 AM
MEANB18
Mar 21, 2004 02:55 PM
OverBoost1
Jan 28, 2004 03:12 PM
smslude
Mar 7, 2003 11:11 AM
H22pwrd
May 12, 2002 11:55 AM
