Which header is this?
Old Dec 4, 2002 | 09:57 PM
Downey's Avatar
Default Which header is this?
looks pretty nice. Is it a DC sports?
Old Dec 4, 2002 | 09:59 PM
JabroninWARRIOR's Avatar
Default Re: Which header is this? (Downeybear1)
yup
Old Dec 4, 2002 | 10:11 PM
rjr162's Avatar
not trying to be a smart-***, but seeing how everything else under the hood is DC sports, it would be a fair guess to say the header is too
Old Dec 4, 2002 | 10:12 PM
SuperSH's Avatar
Default Re: Which header is this? (rjr162)
damn, he cramed that h22 in there.
Old Dec 4, 2002 | 10:28 PM
Mike95lude's Avatar
that looks to be a DC Sports stainless steel 4-2-1 2-piece header.
Old Dec 5, 2002 | 12:19 AM
Neb's Avatar
Neb
is that a civic? that looks like one pretty darn tight fit
Old Dec 5, 2002 | 06:03 AM
rjr162's Avatar
Default Re: Which header is this? (Neb)
it is, check out the headlight... that nice "cute" look as my girlfriend called my 98 civic's look.. but the engine its self looks like it might be just the B16 decked out in DC sports parts. If it's not, then why does the DAC line up just like it should? The mounting bracket lines up just like the B16 one would in a civic. Honestly it looks just like the B16 setup my ex-manager has in his civic. Maybe it's not, but it sure looks just like his engine bay
[Modified by rjr162, 3:05 PM 12/5/2002]
[Modified by rjr162, 3:37 PM 12/5/2002]
Old Dec 5, 2002 | 06:32 AM
ZoNe_HKS's Avatar
thats def a h22, look at the valve cover.. no way its a b16!!!
Old Dec 5, 2002 | 06:55 AM
VTEC-DA's Avatar
Old Dec 5, 2002 | 07:01 AM
kidaniel's Avatar
Default Re: Which header is this? (PDP_HKS)
Yep, sure is. Mine looks just like it. When you first get it, it's a shiny stainless steal. Then after a while it starts to turn goldish. Looks nice.
Old Dec 5, 2002 | 07:26 AM
satan_srv's Avatar
Well there are many things that tell you it's an H22a....the simple one is the rubber stopper for checking the timing at the flywheel, and the front engine mount holes on the block that aren't being used...power steering pump missing....blah blah
[Modified by satan_srv, 11:26 AM 12/5/2002]
Old Dec 5, 2002 | 08:06 AM
rjr162's Avatar
Default Re: Which header is this? (satan_srv)
wow, after a second look, i noticed the alternator is in the front, not the back.. so it is an H22... honestly it doesn't look that big in there. My mistake!
my civic (98 hx) had the rubber stopper on the tranny to check flywheel also... and my manager's 99 Si has everything stripped, so the steering pump/etc wasn't as much of a visual clue to me as to some. I'm use to not seeing it there heh. I guess like i said above hte biggest clue, and the one I really overlooked, was the alternator being in the front like it is
[Modified by rjr162, 5:08 PM 12/5/2002]
Old Dec 5, 2002 | 09:06 AM
Furry
Guest
Posts: n/a
the easyest way to tell is look at the distributor... its on hte exhaust side on a h22, ona b motor its on the intake
Old Dec 5, 2002 | 02:41 PM
BoostedH23a1's Avatar
Default Re: Which header is this? (Furry)
yes its a h22.. only the h22 has the vtec in that spot.. maybe the accord dohc vtec too but... its a DC sports stainless steel header..
Old Dec 5, 2002 | 03:32 PM
dustywebber's Avatar
Default Re: Which header is this? (BoostedH23a1)
im a noob...
so why does it turn gold?
Old Dec 5, 2002 | 04:05 PM
KS-R's Avatar
Default Re: Which header is this? (dustywebber)
Bah.. you think that's crammed? Wait till you see the H22 in an 89 H/B... That's crammed.
hrdsktr1988
Honda Civic (2006 - 2015)
Jun 19, 2008 08:27 AM
92eg6
Dec 7, 2005 07:46 PM
ff terror
Mar 27, 2005 02:12 PM
B16Anis
Apr 21, 2003 11:46 AM
SOHC_MShue
Oct 11, 2002 07:59 PM
