H23 Head studs?
Old Feb 18, 2003 | 03:43 PM
noslude93's Avatar
Default H23 Head studs?
Does anyone know if they make a ARP head stud for the H23?
I would like to get a new head stud. Dont know if they make them ?
It doesnt have to be ARP.
I know they make them for the H22 So would those work?
It seems dumb to build everything and the head and not go with a better head bolt?
Old Feb 18, 2003 | 04:40 PM
BoostedH23a1's Avatar
Default Re: H23 Head studs? (noslude93)
yes but i belive they are prototypes. gudeh23 and quicklude have them i know
Old Feb 18, 2003 | 06:53 PM
noslude93's Avatar
Default Re: H23 Head studs? (BoostedH23a1)
They have the H22 studs?
Old Feb 18, 2003 | 09:34 PM
PrecisionH23a's Avatar
call arp and ask to speak with al nichols, he will take good care of you. yes i had mine made as a prototype. 805.339.2200
[Modified by GudeH23a, 1:35 AM 2/19/2003]
Old Feb 18, 2003 | 10:14 PM
XES's Avatar
XES
I was also looking for some head bolts 2 years ago when I built up my motor...never did get any...
Just to let you know, i've been using the stock head bolts for quite some time, and have been running around 22-24psi with no problems at all. Don't loose sleep over it if you can't get a hold of some...unless you are planning on making more power than 550whp in the near future (on a regular basis).
Old Feb 18, 2003 | 10:18 PM
Default Re: H23 Head studs? (XES)
the factory head studs worked fine for me for a while, but while i had the motor apart i wanted to purchase arp's. plus, they are reusuable... i didnt want to use my original oem's more then 2x even though you are supposed to replace them each time you pull your head.
Old Feb 18, 2003 | 11:12 PM
IloveNewt's Avatar
i just had arp send some of thier new h23 studs they produced. Wow, 22 psi on stock bolts is prett impressive. At 13 psi im pretty sure my head lifted on my stock headstuds. Not 100% sure yet, ill know in a week or two.
But yea ARP has h23 studs now im pretty sure.
Old Feb 19, 2003 | 12:45 PM
h23vtec_dc2's Avatar
Default Re: H23 Head studs? (MordecaiPSI)
h22 head studs are longer than the h23 too.. but just to let you know, i have some h23 studs if you want em..
Old Feb 19, 2003 | 08:57 PM
Quiklude's Avatar
Default Re: H23 Head studs? (h22mugendc2)
well when i put my motor together, i decided to go with the whole insurance package, i talked to the guys at ARP and got the prototype h23 headstuds, and got the h22/h23 main stud kit too, it ended up being 250$ for both.....i think it was Mike Rose that i talked to at ARP......Hope that helps some
team_lunatics
Nov 26, 2011 05:26 PM
j3wman
Nov 4, 2009 03:34 AM
H23civichatch
Mar 14, 2009 08:29 PM
hondamark35
Nov 1, 2008 01:28 AM
hondamark35
Oct 31, 2008 05:05 AM
