H22a4 block prep
Old Sep 16, 2016 | 09:21 AM
skippy33's Avatar
Default H22a4 block prep
I have been reading for hours on here and need the best answers for my situations..I am using a4 block with JDM pistons..pistons are brand new can i get away with not honing my block if not what grit do I hone with..I been reading alot about rings I have gotten a set of Eve or evergreen same company do I use these or go to the npr rings...any help would be great..
Old Sep 16, 2016 | 11:11 AM
snobordboy's Avatar
Moderator
Default Re: H22a4 block prep
In regards to honing, 2 things. 1 is piston to wall clearance, if it is within spec or not. 2 is wall condition, if you catch a fingernail on any scratches it needs a hone.
the frm walls use a special honing technique, which is detailed in the factory "helms" service guide, and there is a link to those guides in the FAQs.
I would use oem Honda rings, or Nippon.
Not sure which pistons you have, but I am still out on if the Nippon oem style pistons are really compatible with frm or not. Only time will tell, but I have not heard of anyone building an engine properly with them yet to give good feedback
Aradin's Avatar
Premium Member
You should NOT hone/deglaze an H series with tools designed for more typical iron sleeved engines. If there are no vertical scratches that run the length of the bore and there are no other major defects you DO NOT need to hone the FRM sleeves. Simply re-ring and go. Use the rings that came with the pistons.
Old Sep 17, 2016 | 05:06 AM
skippy33's Avatar
Thanks I appreciate the info...
Old Sep 17, 2016 | 05:11 AM
skippy33's Avatar
One more thing I was previously told I could run my milled head( .20 taken off) without adjustable cam gears I just wanna confirm this as I am not doubting the individual that told me this just like to get more than one input on that..thanks fellas for all the info..
Old Sep 17, 2016 | 03:30 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
There is NO good reason to mill a Honda DOHC head that much... stop listening to DOMESTIC engine builders on how to make more HP. Milling the head retards the timing event in relation to the crankshaft and you reduce quench area. Cam gears are used to adjust the belt-induced issue out and a custom Cometic head gasket will put back your quench if you add the milled amount of the head to the OE gasket thickness.
In short: If you want to cross your finders and hope you gain some power, go no cam gears. If you want to maximize your power, get a pair of gears and DEGREE them before installing the engine in the bay.
Old Sep 20, 2016 | 03:11 AM
skippy33's Avatar
Thanks I appreciate the info I have another head not milled I am gonna just use that one..
ef4real
Honda S2000
16
May 15, 2014 06:23 PM
diouf
Sep 30, 2011 08:07 PM
18gLUDE
Feb 15, 2005 06:04 AM
SnOOpY-NO
Jan 12, 2005 08:09 AM
untitled
Jul 19, 2003 03:18 PM
