h22a timing belt walking off the cam gears
Old Jan 23, 2012 | 07:47 AM
  #26
Motoer head's Avatar
Default Re: h22a timing belt walking off the cam gears
i got fed up with it and took it to a shop and head them put it on and the same thing happened i got all the new parts and it makes no sense and i ran it with the valve cover off and it dus not go off the gears at all i put it back on and drive it and it shreds the belt in so lost on what to do next could it be that my toner messed up on the ecu and my motor is running higher rpm than the belt can handle? i am up to try eny thing i got almost $$$1000 into this timing belt grimland and im about to throw this motor away and stort over
Old Jan 23, 2012 | 09:52 AM
  #27
snobordboy's Avatar
Moderator
Maybe take a bunch of pictures of the whole assembly, so we can see what exactly is there, and maybe spot a problem?
Old Jan 30, 2012 | 07:41 AM
  #28
Ok so I got all the new parts on the manual tensioner and all the balance shaft stuff back on as well. I put a new water pump on it and that ware I think I have fawn my problem the bolt that goes thro the timing belt tenshoner idler pulley was cross threaded and broke coming out so I went to Honda and got the bolt its all back together now but it has a lot of belt wine it almost swords like it has a super charger what could that be do you think I got the belt to tite?. And its staying on the cam gears now dut just making a weird sound
Old Jan 30, 2012 | 07:59 AM
  #29
rchid's Avatar
the wining sound usually means the belt is too tight and putting strain on bearings, which can lead to the bearings giving out down the road.... somebody correct me if I'm wrong.
Old Jan 30, 2012 | 08:53 AM
  #30
so would that meen the bearings will go out as in crack the rases jump the belt exetra..
Old Jan 30, 2012 | 08:54 AM
  #31
could the belt be so tight that it will pole itself apart?
Old Jan 31, 2012 | 04:32 AM
  #32
rchid's Avatar
I think it would snap before it would shred in that case... but seeing how your timing belt has a history of walking off something could be leaning, which will in turn put more stretch on one end of the belt that can cause it to tear instead of snap but i think that's less likely to happen.
1_fst_lude
Sep 26, 2006 11:36 PM
NoVALude
Jul 19, 2006 11:53 AM
SrT4u2nV
May 23, 2006 08:40 AM
DeDonDeRosa
Apr 6, 2006 09:18 AM
