H22A Question
Old May 2, 2002 | 06:32 PM
ZColeon's Avatar
New User
Default H22A Question
Are the stock pistons on a 2.2 A full float wrist pin or a press pinn.
Reasonbeing, I would like to get forged pistons and still utillze my stock rods.
Are the stock rods of any substantial strenght. What are there limits?
Running 11.0-1 pistons ona type S, and wondering how much work can be done and still be able to use pump gas on a regular basis. Any help would be absolutly cool.... Thanks..
Old May 2, 2002 | 06:46 PM
Smurfylude's Avatar
Default Re: H22A Question (ZColeon)
If you've seen the other posts. If your going to run forged pistons on an H series motor your going to need to resleeve the block. I ran into the same problem..
Prelude Vtec 23's Avatar
Press pinn, you need to press the pin out w/ a hydraulic press.
Old May 3, 2002 | 09:58 AM
ZColeon's Avatar
New User
Default Re: H22A Question (Sushi X)
Why did you need to re-sleeve the block, Why cant you hone the cylinders / new rings and be good to go?
Old May 3, 2002 | 11:28 AM
Smurfylude's Avatar
https://honda-tech.com/zerothread?id=176354
Old May 3, 2002 | 01:25 PM
DirtyLude's Avatar
The H22a1 had pressed wrist pins. The H22a4 has floating wrist pins held in with clips.
VSBB6
May 16, 2006 09:09 AM
MyVtec8yourV8
Aug 29, 2004 10:34 AM
Morhpeous
May 2, 2004 04:43 PM
BUCKO5
May 16, 2003 01:51 PM
dvp95
May 15, 2002 11:38 PM
