h22a problems
Old Nov 21, 2005 | 12:23 AM
IOSUA's Avatar
Default h22a problems
i have a question. im running a h22 in my 01 integra. i took off my butterflies and the IAB box. im running a chipped p13 Spoon ECU with no check engine light. my first and second gears is fine but when i click 3rd i have a red line at 6500. my redline on my ECU is at 8,500. why do i have a redline at 6500 in 3red gear? can anyone help me out. thanks.
Old Nov 21, 2005 | 05:15 AM
The Weather Man's Avatar
Why? Because you bought some cheap wannabe spoon chip off eBay probably.
Get a different chip first off.
Second off - why is the redline at 8,500?
Third - of course the chip is the problem with the MIL light.
Get a different chip - or ecu. Enough said.
Old Nov 21, 2005 | 05:16 PM
IOSUA's Avatar
haha. im not sure if its from ebay but i dont think so. maybe i should take off tha chip and see how it runs stock.
Old Nov 21, 2005 | 05:19 PM
intake's Avatar
B A N N E D
Default Re: (jdm dc2 01)
why dont u run a chipped p28?
Its gotta be the chip.. 8.5k redline isnt that a Bit high for a h22?.. i always shift at 7.5-8k at the most
Old Nov 21, 2005 | 05:34 PM
IOSUA's Avatar
i always have been shifting at 8.5k for a while now. for about 5 months.
whats so different from a chipped p13 than a chipped p28 anyways?
Old Nov 21, 2005 | 05:42 PM
intake's Avatar
B A N N E D
i think in the p28 u can delete the Knock Sensor.. the EGR .. only thing that sucks is that on the p28 u can only run a single intake manifold system.. instead of the butterflies..
I read it a import mag somewhere.. u lose like 10hp i think..
Old Nov 21, 2005 | 06:02 PM
IOSUA's Avatar
so by removing butterflies, i can lose HP? so u think my chip is reading the EGR and knock?
Old Nov 21, 2005 | 06:34 PM
Get a chipped p72 ecu. Throw away that ebay junk - because itll just cause problems. A real chip would cost way more than ebay crap.
what mods do you have?
Old Nov 21, 2005 | 06:37 PM
IOSUA's Avatar
Default Re: (TheKingPin)
i just got dc headers and an intake. no cat. no butterflies. comptech catback. no motor work done so far.
Old Nov 21, 2005 | 07:01 PM
draxxus07's Avatar
u dont need a p72, just get a p28 u dont lose hp because u dont have butterflies, and yes u do lose the knock sensor but thats pointless, its like having a "motor just blew" sensor... as for the redline with your mods u dont really need that high of a redline, i think h22s drop off after 8000 but to each their own
Old Nov 22, 2005 | 05:10 AM
mgags7's Avatar
youre retarded draxxus....honda would never put a sensor on the block to detect a blown motor.....
the knock sensor "listens" for pinging, or detonation on a smaller scale.....when you are exploding a bit early, due to odd timing and fuel issues in the low rpms, the knock sensor helps the ecu adjust timing in order to minimize pinging and detonation....
p72=good
without butterflies you will lose no top end hp, unless you took the plate out, then you will lose a few horse...but you lose a lot of low end w/o butterflies....get a p72....
7800 is the highest you could possibly want to go.....
Old Nov 22, 2005 | 05:16 AM
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">youre retarded draxxus</TD></TR></TABLE>
His Avatar explains it all.
masijdm
19
Jun 11, 2009 09:11 PM
RhdRicheeee
Feb 28, 2009 10:40 PM
O RLY
Oct 5, 2004 10:42 PM
O RLY
Oct 5, 2004 08:01 AM
Ddogz15
Apr 15, 2004 12:34 AM
