h22 idle problems
Old Feb 2, 2005 | 07:34 PM
Turbokid13's Avatar
Default h22 idle problems
h22 is idling at 1400-1700 rpms after warm any ideas please let me kno
Old Feb 2, 2005 | 09:31 PM
PrettyLude's Avatar
did you try adjusting the idle?
Old Feb 2, 2005 | 10:00 PM
lyric911's Avatar
Default Re: (PrettyLude)
How does one adjust idle speed btw. Mine idles a touch rough, but increasing like 50 rpms and all roughness goes away. Might as well set it to idle just a bit faster.
Old Feb 2, 2005 | 11:09 PM
homesauce's Avatar
Default Re: (lyric911)
THere's a big screw on/near the throttle body to adjust idle
Old Feb 3, 2005 | 09:46 AM
vtecludeh22's Avatar
Default Re: (homesauce)
check all the vacume lines on the intake manifold and the fuel pressure regulator to make sure they are hooked up
Old Feb 3, 2005 | 02:29 PM
Turbokid13's Avatar
Default Re: (vtecludeh22)
already tried to adjust the idle screw and no effect, my check engine light is on showing something is up with my throttle position sensor and O2 sensor, already checked the tps and it is right on the money,
Old Feb 3, 2005 | 02:49 PM
89sih22a's Avatar
hmm thats wierd i have the same problem
how can i check to see if my tps is right on the money there is no markings?
Old Feb 3, 2005 | 08:56 PM
PrettyLude's Avatar
check it with a multimeter. it should read .5 at close and 5.0 V at wot
cfoland
Feb 19, 2011 08:33 PM
RudeLudeHatch
Dec 14, 2008 06:47 PM
JasonST
Jun 30, 2006 11:22 AM
FastSS
Aug 31, 2004 09:20 AM
matix
Mar 15, 2004 09:28 AM
