h22 idle problems
h22 is idling at 1400-1700 rpms after warm any ideas please let me kno
did you try adjusting the idle?
Re: (PrettyLude)
How does one adjust idle speed btw. Mine idles a touch rough, but increasing like 50 rpms and all roughness goes away. Might as well set it to idle just a bit faster.
Re: (lyric911)
THere's a big screw on/near the throttle body to adjust idle
Re: (homesauce)
check all the vacume lines on the intake manifold and the fuel pressure regulator to make sure they are hooked up
Re: (vtecludeh22)
already tried to adjust the idle screw and no effect, my check engine light is on showing something is up with my throttle position sensor and O2 sensor, already checked the tps and it is right on the money,
hmm thats wierd i have the same problem
how can i check to see if my tps is right on the money there is no markings? |
check it with a multimeter. it should read .5 at close and 5.0 V at wot
