are the h22 eagle rods the same as the h23???
I need to know if the eagle rods for the h22 are the same length and all for my h23 motor, i am running wisco pistons
If so, what is eagles site, or a good place to buy them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.4roadrunner »</TD></TR><TR><TD CLASS="quote">no, they won't work.</TD></TR></TABLE>
Okay, well what rods should i run, I am going all motor, but I want something stronger then factory, I know crower makes some, but they are expensive, any suggestions
my engine builder called wisco direct, i am actually going to run a new h22 piston in my h23 that is comming out in a week or two.
As for the rods, these companys make them
Pauter 619-422-5384 around 720 a set from them
Crower 619-422-1191 677 a set from them
cunningham 310-538-0695 720 a set from them
I have been told that you can find better prices if you do a little shopping, so far crower seems to the the cheapest, i have talked to all 3 companys on the phone and they all have a lot of respect for each other
BUT the all say that eagle rods are imported from japan and that they suck
you can use h22 eagle rods, you just have to have the piston made w/the wrist pin moved up to make up for the increased lenth of the rods...this also helps improve the r/s ratio slightly.
interesting, but that means i have to run custom pistons which take a month to get right?? I also have heard a lot of bad about eagle rods in the last few days too. I am kind of thinking crower for both performance, price and I can get them easy
what did you here? ive heard bad things about all, but ive heard good also. ive heard of people making 600+ whp on eagles...i have a set in my car right not w/1000 mi. on them, but im thinking of upgrading to pauters.
heard the eagles where imports from japan, and that they are poorly forged with inconsistant heat treating. Crower, pauter and cunnigham are all US made, sounds like they are worth the price, they have all been tested in motors close to a 1000hp, lisa kubo ran cumminghams along with all the AEM civics
