Got a problem with bogging while driving and shaking of car
While im cruising in any gear or even starting in first gear if i tap the gas lightly in 4th gear on a straight road it would bog and feels like im shaking around 2500-3500rpms this only happens if im in like 3rd gear at 4k rpms and floor it itll be less boggy and pick right up (fidanza flywheel). what is wrong?
I can't tell from your description, does it happen in all gears at the same RPM? If so, I'd check the cat first. Any CELs?
(your description is not worded very well)
i know sorry i was a little out of it when i wrote it...
It happens if the engine isnt at high rpms like 4k+. or if i tap the gas lightly the car shakes back and forth and if i floor it in second from like 2 rpms itll bug until 3500ish and take off. its a h23
i had a similar problem and finally i found out that the spark plug wires werent long enough... they were for wrong car so i went back to store and got the right ones and now its fine! maybe thats it idk possibility..or a dead spark plug not firing maybe
thanks bro ill try that because when im in second slowing down and i let the rpms drop it just shakes to keep moving back and forth.
yeah could be a spark plug gone bad because in my dads car it does that alot and it feels like the damn engine wants to fall out!!
word i just got brand new denso plugs a couple weeks ago. i just need wires now! what do you guys recommend? ngk what?
I had/have the same problem, when i took one of my plugs out it was saturated in oil. I ordered new tube seals and hopefully it will fix the problem.
not necesarrily egr... i have no egr and that doesnt happen.. it throws a cell for it but doesnt make my car run like sh*t...
Aphelion
Aug 6, 2005 11:17 PM
kim_2_da_chee
Feb 16, 2003 10:52 AM
