Getting a code 41
Old Jul 1, 2004 | 03:23 PM
delguiner's Avatar
Default Getting a code 41
I'm getting a code 41... which means primary oxygen sensor heater, circuit malfunction... does this mean my O2 sensor has to be changed? its a 1992 prelude SR 193,000kms... thanks boys
Old Jul 1, 2004 | 03:35 PM
Nikoli's Avatar
Default Re: Getting a code 41 (delguiner)
yes you have a bad o2 sensor
Old Jul 1, 2004 | 04:20 PM
ludermark's Avatar
Default Re: Getting a code 41 (95deckedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95deckedlude &raquo;</TD></TR><TR><TD CLASS="quote">yes you have a bad o2 sensor</TD></TR></TABLE>
Old Jul 2, 2004 | 06:53 AM
delguiner's Avatar
Default Re: Getting a code 41 (ludermark)
could it also mean that i have a bad circuit connection or its the sensor for sure? cause im getting pretty bad idling so im thinking that COULD be the problem?!?
Old Jul 2, 2004 | 08:37 AM
Sephro's Avatar
it could the the wires but more than likely it's a bad sensor. The rough idling could be because of the O2 sensor.
They are open/close loop systems. When the sensor is bad or throwing a code it switches to the closed loop meaning that it uses the programed Air/Fuel ratios. When the sensor is working the goes into open loop meaning that it takes readings from the sensor and determines the Air/Fuel ratio.
Old Jul 4, 2004 | 11:51 AM
sfjdmlud3's Avatar
how would you know if its a circuit malfunction or if the o2 needs to be replaced? Whats a code 36? Also a code 22 is something about vtec oil pressure?? What would that do? Will that make the engine not run right? Been running with a CEL for the longest time. just recetly pulled the codes and got 22 36 41. any help is apreciatied.
Old Jul 7, 2004 | 11:27 AM
Sephro's Avatar
Default Re: (sfjdmlud3)
Do you have the H22??
Old Jul 7, 2004 | 11:45 AM
delguiner's Avatar
Default Re: (Sephro)
No i have a H23...
Old Jul 7, 2004 | 12:41 PM
Sephro's Avatar
Default Re: (delguiner)
huh... no Idea why you would be getting a VTEC code then...
If I where you, I would check all the codes again. Write them all down then reset the ECU. See if any come back. I have never seen anything for a code 36 before...
Maybe someone here knows if there are more codes than what are listed in the Helms??? Personally I have not come up with any.
Old Jul 7, 2004 | 05:26 PM
delguiner's Avatar
no no dude sorry... i have a H23 and i'm running a code 41... oxygen sensor circuit malfunction... before i would get a code 2 which is primary oxygen sensor failure or whatnot, but now im not getting that anymore... im just getting code 41.. any help?
Old Jul 8, 2004 | 01:10 AM
sfjdmlud3's Avatar
sorry....im the one with the H22 gettin codes 22, 41, 36. my 41 went away after unpluggin and repluggin the o2 sensor. Probably is a bad o2 but no code was thrown after doing that. 36 is 4ws code if you have a ecu that came off a 4ws prelude. It will not throw a check engine light though, so no worries there. 22 is a vtec malfunction?? Thats the one im askin about. thanks
Old Jul 8, 2004 | 06:08 AM
Sephro's Avatar
ohhh whoops. I didn't even notice that there was 2 of you posting codes
For the O2 sensor code you need a new sensor. No way really around it.
Here is a list of the codes... I think they are all the same but I didn't check them all. http://www.151boost.com/tech2.htm
Old Jul 8, 2004 | 06:44 AM
delguiner's Avatar
41 Primary Oxygen Sensor - Heater
circuit malfunction
this is what the code indicates... Now could it be the circuit or for sure its the sensor???
Old Jul 8, 2004 | 07:08 AM
94vtecmn's Avatar
You can test the curcuit, with the proper tools, by tapping into the wiring on the O2 sensor itself, to see that you have continuity. But, it's most likely the sensor itself.
I recently helped a neighbor of mine remove his O2 sensor that was simply shorting out at the sensor, but he had to replace the sensor to fix that as well.
Old Jul 8, 2004 | 07:16 AM
Sephro's Avatar
Default Re: (94vtecmn)
I got the same code (41) and I replaced my o2 sensor and the problem went away. There is no way to replace just the heater it's all one unit. Costs more than the standard O2 sensor but... oh well nothing you can do about it.
Old Jul 8, 2004 | 07:24 AM
delguiner's Avatar
during that time did you have idleing problems? when you had the code that is
Old Jul 8, 2004 | 08:22 AM
Sephro's Avatar
No I did not notice any idle problems that I can recall. It was almost 2 years ago though.
Old Jul 8, 2004 | 08:32 AM
delguiner's Avatar
ok well thanks for your help anyway!
EGY8
Jul 27, 2006 12:49 PM
SONIC BOOM
Jun 23, 2006 06:40 AM
claytonsmith
10
May 16, 2006 12:01 PM
stephen_civic98
Dec 12, 2005 11:15 AM
hybridEj6
Oct 26, 2003 05:53 PM
