G23 issues
Old May 18, 2010 | 05:01 PM
jdmf22dohc's Avatar
Default G23 issues
hey i searched but couldnt find any topics on this:
i've built a g23, the first day i ran it was perfect, then i noticed some oil leaking from the head gasket (i used the h22a4 head gasket-which is wrong-the oil drains on the gasket are bigger than on the block) so i installed a f23a1 and i can not get it to run if im on the gas its fine but the moment i let off the throttle it dies completely here is a list of what ive done:
h22a4 head
f23a1 block
f23a1 head gasket
vtec is not hooked up yet (have apexi vtec controller to hook up)
mitsubishi eclipse 450cc injectors
removed the low rpm torque throttle plate (middle of manifold)
removed the cruise control
removed all egr components (carbon canister,electronic valves and such)
all vacuum lines off the manifold are blocked
k20 pistons on f23a1 rods
all arp studs (everything is studded)
removed the air box from the fender and all vacuum lines from the mani
no oxygen sensor (have to make the wires longer)
h23 stock ecu
timing is perfect checked it 50 times or more
at this point any help would be wonderful ive exhausted all the options i can think off and a new set of "eyes" on the subject would be a geat help
thanks in advance for all your help
Old May 18, 2010 | 08:49 PM
LobeSex's Avatar
Default Re: G23 issues
try running the h22 ecu? just an option
Old May 19, 2010 | 05:40 AM
92civlude's Avatar
You mentioned all vacuum lines are blocked. Did you also block the fuel pressure regulator? You should hook up the FPR correctly, repair the O2 sensor wires and run a P13 ECU. See what happens.
Old May 19, 2010 | 08:01 AM
kornkid21792's Avatar
your biggest problem is that your running that h23 ecu a stock ecu cannot run your setup properly
Old May 19, 2010 | 08:31 AM
92civlude's Avatar
Youre also running Non-Honda injectors. Are they low or high impedance? Did you bypass the injector resistor?
Old May 19, 2010 | 09:23 AM
jdmf22dohc's Avatar
all my FPR lines are hooked up, ive got my hands on a h22 & p13 ecus that im gunna plug in tonight. and see if that works.
Old May 19, 2010 | 09:26 AM
jdmf22dohc's Avatar
Originally Posted by PirateMcFred
Fück that. You're running 450cc injectors on an ecu designed to run 235ccs untuned on an engine that's not even supposed to use P14 ecu. It's pig rich and you're washing down the cylinder walls with fuel and you'll ruin your rings. To make it worse you're not running an O2 sensor so the POS ecu can't even try to fix the fuel that you've messed up.
Fix the ECU/sensors and tune ASAP or go work on POS pushrod V8s where all you have to have is a magneto and a carburator to get a 60 year old design to run.
the guy i got my injectors/manifold/head from had the same set up as i've got and he didn't have any problems. but im gunna mess with the car somemore tonight and see what happens. my next step was to change out the injectors and ecu, then its going to a local tuning shop asap
Old May 19, 2010 | 10:10 AM
meanshyguy's Avatar
Don't make the same mistake I made with my H23vtec and run the correct ecu and tune it, I'm still paying for all that, good luck, looks like a nice build so take care of it.
Old May 19, 2010 | 10:31 AM
ilikehonda's Avatar
Think about this lets say the stock injectors (235cc) run at 80% on the stock ecu. You put in 450cc Injectors to run at that same load....think about it. you are using an injector that is almost twice the size of the stock ones....which means twice as much fuel too.
quit trying to tinker with the car until you have the correct injectors and ecu!
btw that apexi will not run vtec. you need to have a vtec ecu!
Old May 20, 2010 | 04:21 AM
jdmf22dohc's Avatar
Changed out my injectors last night, back to stock and the car runs like a completely different car. It ran and sounded strong. Finally after a long 8 months, the swap is done.
Old May 20, 2010 | 04:36 PM
jdmf22dohc's Avatar
so it runs strong when im on the gas im still running the h23 ecu, back to stock injectors, every time i step on the clutch it dies, if its in gear it runs perfect, neutral with foot off the clutch perfect, step on clutch dies, ummm what could that be? thanks for all your help so far i really appreciate it.
Old May 20, 2010 | 06:47 PM
jdmf22dohc's Avatar
N will the apex controller not seriously run vtec?
Old May 21, 2010 | 06:46 AM
ilikehonda's Avatar
it seriously will not run vtec. you need a vtec ecu in order to have vtec. the controller only allows you to adjust vtec. if the ecu doesnt tell the vtec solenoid to go then you will never have vtec....unless you white trash it and hook up a switch. but then you will have other problems
Old May 21, 2010 | 07:44 AM
bigirb2002's Avatar
bro listen to us. you are going to screw yourself. buy a chipped p28 ecu and i will give u a basemap to run on so you can drive it to get it tuned. dont be stupid an *** yaself
Old May 22, 2010 | 11:50 AM
jdmf22dohc's Avatar
I drove it to my local tuner shop last night, having them look over everything and get it so i can drive it daily.
Old May 22, 2010 | 12:14 PM
1sicef9's Avatar
is it worth doing a g23 swap?i have a clean f23a4 short block
Old May 22, 2010 | 07:26 PM
chrischhorn's Avatar
Listen to these folks......TUNE IT! There is no stock ecu that will run your motor correctly! You need a chipped p28 or p72 to get your motor tuned. When you tune it you COULD use the 450cc injectors since you dont wanna go over 80% duty cycle on your stock injectors. Just as any build of any sort, you need a tune immediately afterwards or all your hard work is gonna just disappear. If you need more info on the G23 build, try www.cb7tuner.com . There have been a couple guys to pull it off correctly. LoDollar92LX has a G22(used an f22b block) and is pushin 526whp on 18psi and daily drives it on 93 octane.
mijos
Sep 5, 2020 05:56 PM
titan101
Sep 23, 2011 03:48 PM
ghozt107
Jul 25, 2010 10:14 AM
scspeed
Apr 18, 2009 01:54 PM
BigBoulda
Aug 19, 2005 09:43 AM
