which fuel pump
255 is way overkill for an NA motor, espcially since your only pushing 370cc, you probably couldnt out flow at 190lph walbro at 100% duty cycle and 60psi,
Go with a 190, unless your planing to spray like a 200shot or something rediculously high.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx »</TD></TR><TR><TD CLASS="quote">255 is way overkill for an NA motor, espcially since your only pushing 370cc, you probably couldnt out flow at 190lph walbro at 100% duty cycle and 60psi,
Go with a 190, unless your planing to spray like a 200shot or something rediculously high.</TD></TR></TABLE>
Really you think so. Hmmm I dont know. How much is the stock vtec one?
Also how do these sound I.E. are they really loud and high pitched. I dont care just curious.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Icey112 »</TD></TR><TR><TD CLASS="quote">this should help you a little the SOHC/DOHC NON VTEC flows at 79lph and the DOHC VTEC flows at 135lph. </TD></TR></TABLE>
****** a right. I couldnt find that any where. I think the 190lph should be fine for me then if thats true
190 will do fine thats what im runing b16a2 and a 75 shot of zex . My boy made over 400hp with the same fuel pump he just got a 255 going for more boost so i got his 190 now and loven it
