Fuel Line Size
Old Mar 14, 2003 | 08:52 PM
LudeyKrus's Avatar
Default Fuel Line Size
What's the size for a lude's fuel line?
Old Mar 14, 2003 | 09:08 PM
JDM BB2's Avatar
Default Re: Fuel Line Size (LudeyKrus)
If your looking to run steel braided line, use -6 AN. If you want a stock replacement, contact your local Honda dealer and ask them. Any local auto parts store should also be able to supply you with the hose...
-Mike
Old Mar 15, 2003 | 08:43 AM
LudeyKrus's Avatar
Default Re: Fuel Line Size (JDM BB2)
I believe it's 5/16". but i'm bout to make a tee and i'll be using some barbed splines to connect the line, so I need to figure out the line size to get the right size splines. Anyone know?
Old Mar 15, 2003 | 12:38 PM
BoostedH23a1's Avatar
get barbed fittings... its -6N line for braided and 5/16 in Fuel injection hose.. if u use reg rubber hose make sure its for pgm-fi.. or it will crack
Old Mar 15, 2003 | 10:21 PM
LudeyKrus's Avatar
Default Re: Fuel Line Size (BoostedH23a1)
that's what i needed to know....thanx!
Old Mar 11, 2019 | 07:16 AM
Justin Branham's Avatar
-Mike
is it the same for the return line as well.
Old Mar 12, 2019 | 01:19 PM
snobordboy's Avatar
Moderator
Same or smaller.
AWD Terror
Feb 3, 2017 11:59 AM
elmalouno
Aug 20, 2010 11:17 AM
Bond
Feb 16, 2010 11:25 AM
dkrex001
Oct 23, 2007 06:40 PM
si92hb
Dec 11, 2004 03:33 PM
