Fuel Line Size
What's the size for a lude's fuel line?
Re: Fuel Line Size (LudeyKrus)
If your looking to run steel braided line, use -6 AN. If you want a stock replacement, contact your local Honda dealer and ask them. Any local auto parts store should also be able to supply you with the hose...
-Mike |
Re: Fuel Line Size (JDM BB2)
I believe it's 5/16". but i'm bout to make a tee and i'll be using some barbed splines to connect the line, so I need to figure out the line size to get the right size splines. Anyone know?
get barbed fittings... its -6N line for braided and 5/16 in Fuel injection hose.. if u use reg rubber hose make sure its for pgm-fi.. or it will crack
Re: Fuel Line Size (BoostedH23a1)
that's what i needed to know....thanx!
Originally Posted by JDM BB2
(Post 4606830)
-Mike |
Re: Fuel Line Size
Same or smaller.
