f20b head
the f20b head has a factory 3 angle valve job which is pretty dam good, but the valves are 1mm smaller then a h22a due to the smaller bore diameter of the cylinders.
mild factory port polishing also.
if you are planning on using it on a h22a block you would be much better off withthe h22a head, also f20b's have a tendacy to drop valves.
Pikey
39
Aug 1, 2006 01:02 PM
hanginlow
Apr 13, 2003 07:40 PM
