exhaust
Old Feb 19, 2013 | 06:26 PM
prelude447's Avatar
Icon2 exhaust
i was going to try and take some advice on what kind of exhaust i should run on my prelude what do you guys suggest?
Old Feb 19, 2013 | 07:28 PM
Bouckaroo's Avatar
Default Re: exhaust
i have 3 inch cusotm built jobby. highgly recomended to do the same, as the alrger piping realy opens up the h22.
Old Feb 19, 2013 | 07:37 PM
98vtec's Avatar
moderator emeritus
Default Re: exhaust
depends what you are using the car for
Old Feb 20, 2013 | 09:17 AM
prelude447's Avatar
Default Re: exhaust
how much dies that run for? and im going to end up putting a turbo on the car. im not in any price range im looking for a high stage exhaust for the track but im looking for a crisp sound also
Old Feb 20, 2013 | 10:31 PM
BlackCatt's Avatar
Default Re: exhaust
Which engine is this for h22 or h23? Cause if you want to run
a conventional setup until you go turbo, the choice of header
is very important. There are only a few header choices for the
h23. The h22 has alot of choices and if you want one that flows
better than stock, then you need to go with a quality piece. As
for the rest a high-flow cat and muffler will be needed and you'll
definately want a resonator too if you are going to DD it. Mandrel
bends in the piping are better than press bends too. If you are
going to go turbo soon, you may as well do that straight away,
cause the system will be much different.
Old Feb 21, 2013 | 11:46 AM
92PurpleLude's Avatar
Default Re: exhaust
3" exhaust is plenty for all motor or boost vehicles, so unless you want to build the exhaust twice this should be your choice. I would go for vibrant exhaust components and possible a second resonator depending if you are into the lawnmower sound. Also if you want to turbo don't blow your money on fancy headers just get something cheap like Megan and use exhaust wrap to speed up the exhaust gas. Some shops might give you a helping of fresh BS about how they can't build it, but they just don't want to lose money by you bringing your own parts in, but if you can weld then go for it yourself!
Old Feb 21, 2013 | 10:33 PM
gstrudler's Avatar
Default Re: exhaust
3" mandrel bent, high-flow cat, Vibrant resonator in the tunnel and then either a Borla, Magnaflow, Thermal R&D, or Vibrant muffler out the back. There are a couple companies who offer 3" mandrel bent piping kits such as k-teller; grab one of those with your choice of components listed and take it to a shop to have it welded up. I'd just stick with the stock header and put a transition cone in to go up from the stock size to 3" if you're going turbo later.
Or if you live in one their areas, take it to Hytech or SMSP or similar and have them do it all for you.
Old Feb 22, 2013 | 11:53 AM
npav's Avatar
Default Re: exhaust
Mugen
Old Feb 22, 2013 | 01:55 PM
friutoftheLude's Avatar
Default Re: exhaust
still waiting for my Apexi WS2 to be shipped, got the Hytech replica header, was hoping to install them tomorrow, the only day i had garage time
Im not gonna turbo mine though
H23vtecCoupe
14
Mar 28, 2014 01:54 PM
Mfoehrkolb
Jul 1, 2013 07:15 PM
fastdohc
Aug 31, 2010 08:56 AM
23series
Sep 24, 2007 11:44 PM
hprelude93
Nov 9, 2005 01:30 AM
