engine swap si with vtec
Old May 31, 2002 | 06:30 PM
lodown414's Avatar
Default engine swap si with vtec
how difficult is it to swap? or is it possible to slap a vtec head on the si?
Old May 31, 2002 | 06:36 PM
poison's Avatar
Default Re: engine swap si with vtec (lodown414)
what year is yours
[Modified by poison, 8:38 PM 5/31/2002]
Old May 31, 2002 | 07:44 PM
lodown414's Avatar
Default Re: engine swap si with vtec (poison)
93
Old Jun 1, 2002 | 08:29 AM
PrecisionH23a's Avatar
the h23a to h22a swap is very easy. dont do a h23a bottom and h22a head, its nothing but problems and VERY unreliable. go full h22a. http://www.hondaprelude.com/resources/article.asp?id=58
theres a site with instructions on the swap
Old Jun 6, 2002 | 11:16 AM
ViZ's Avatar
ViZ
Default Re: engine swap si with vtec (GudeH23a)
I heard that the block for the h23 is the same part number when there are no internals included, and that the h23 requires no machining the only difiference are the internals of the block so therefor you can run a vtec head on the h23 block no problem... maybe sombody that can get a factory part number can prove this ... its just rumored but i think its true... so basicaly if you have an h22 you can put in the h23 crank rods and pistons... they are both 87mm bore but who knows...anyone?
ViZ
Old Jun 6, 2002 | 12:48 PM
apexii's Avatar
Default Re: engine swap si with vtec (ViZ)
I heard that the block for the h23 is the same part number when there are no internals included, and that the h23 requires no machining the only difiference are the internals of the block so therefor you can run a vtec head on the h23 block no problem... maybe sombody that can get a factory part number can prove this ... its just rumored but i think its true... so basicaly if you have an h22 you can put in the h23 crank rods and pistons... they are both 87mm bore but who knows...anyone?ViZ
You would need many other associated parts that the H23 block does not have. You will end up spending more time and money in the long run, no doubt. Just go with a USDM h22a, a very easy swap!
Old Jun 6, 2002 | 03:13 PM
Default Re: engine swap si with vtec (apexii)
as i stated before... do not waste your time or money on the h23/h22 hybrid. you'll regret it.
ruffie
Nov 3, 2008 09:06 AM
theoriginaljmft
Oct 16, 2006 09:08 PM
alias 33
Jan 10, 2004 08:43 PM
92-h23a1
May 29, 2003 04:39 AM
VRD^don
Jan 29, 2003 02:35 PM
