engine runs ruff
Old Jun 6, 2004 | 09:46 PM
abolish415's Avatar
Default engine runs ruff
ok i just finished installing a H22a engine in my lude right ... i put the coolant and everything .. engine shakes .... anyone know whats going on ?? idles right .. below 1 .. around 800 ...
Old Jun 8, 2004 | 01:28 PM
abolish415's Avatar
Default Re: engine runs ruff (abolish415)
any ideas?
Old Jun 8, 2004 | 01:54 PM
staticrex's Avatar
How are the motor mounts? Good shape?
Old Jun 8, 2004 | 02:55 PM
abolish415's Avatar
Default Re: engine runs ruff (staticrex)
yeah everything is in good shape ... these motor mounts i got were new ... so .. any other suggestions ?
Old Jun 8, 2004 | 06:04 PM
gen4vteclude's Avatar
Does it smoke? if it does what color, does it only do this at idle, does it rev up ok, does it drive ok.
Old Jun 8, 2004 | 06:28 PM
blackdelslo's Avatar
Default Re: engine runs ruff (gen4vteclude)
i know this sounds stupid but do you have your external map sensor hooked up?
Old Jun 10, 2004 | 03:06 PM
abolish415's Avatar
Default Re: engine runs ruff (delLudeVTEC)
wen i drive it .. it shakes .... the idle is cool .. the eternal map sensors .. hmm ima check on it .. thanks guys ....
Old Jun 10, 2004 | 06:58 PM
Goinfasterthanu's Avatar
Could be a good old valve bent from over reving....Just a thought..Mine would run fine till i hit 800rpm then lump,lump,lump. Just an idea..
Old Jun 12, 2004 | 04:53 PM
abolish415's Avatar
Default Re: (Goinfasterthanu)
thanks ... i check everyting and it stills shakes .. any more suggestions ?
Old Jun 12, 2004 | 05:28 PM
PetroGuyX's Avatar
you're sure the motor mounts are secured properly, just because they're new doesn't meant they're not secured well
Old Jun 12, 2004 | 08:06 PM
thehondaguru's Avatar
Default Re: (PetroGuyX)
did you use the energy suspension motor mount inserts?
Old Jun 13, 2004 | 06:02 PM
jackstands's Avatar
Default Re: (95 lude)
after my swap, my engine shook too, it may even want to stall a little, check out the coolant system, air in the system will trick the ect sensor and the computer will add more gas and reduce gas according to sensor temp reading. in other words, bleed the system, it's a real bitch with the h22a's so be patient.
Old Jun 13, 2004 | 06:16 PM
abolish415's Avatar
Default Re: (jackstands)
THANKS GUYS ... you guys were a lot of help ... ill keep it updated .... right on guys
Old Jun 13, 2004 | 06:26 PM
OTT's Avatar
OTT
If it only happens when its in gear then you might wanna have the clutch re-aligned
Old Jun 13, 2004 | 08:54 PM
LudeyKrus's Avatar
First, check to see if it's throwin any codes. Then come back and tell us the results.
Old Jun 18, 2004 | 01:52 AM
luda94's Avatar
check for vacuum leaks, they will definately cause the engine to run rough. usually an easy fix if you find a leak
Old Jun 18, 2004 | 02:42 AM
dc5r2002's Avatar
Default Re: engine runs ruff (luda94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jackstands &raquo;</TD></TR><TR><TD CLASS="quote">after my swap, my engine shook too, it may even want to stall a little, check out the coolant system, air in the system will trick the ect sensor and the computer will add more gas and reduce gas according to sensor temp reading. in other words, bleed the system, it's a real bitch with the h22a's so be patient. </TD></TR></TABLE>
there is a bleeder for it by the thermostat housing, to check for a vacume leak get a mister bottle and spray the hoses, if you notice it bogs down that is the area of the leak
shraz
Honda Civic (2006 - 2015)
Jan 13, 2009 10:33 AM
PrimeElement
Sep 25, 2007 11:46 AM
matrixzteg66
Dec 15, 2004 08:57 PM
sleepyhamsterlx
Dec 4, 2003 07:35 PM
patastinky
Mar 31, 2003 02:16 AM
