engine rebuild
Cost? I have no clue.....
What you'll need:
- Pistons/rings/wrist pins
- Rods
- Main/Rod Bearings
- Head Gasket kit
- Any other block seals that may need to be replaced
Aside from seals, the head should be fine unless the valves are in bad shape. If so, then replacing the valves will be necessary and up the cost.
What you'll need:
- Rods
- Main/Rod Bearings
- Head Gasket kit
