engine question
Old Nov 14, 2001 | 04:00 PM
pr0digy1's Avatar
New User
Default engine question
as Im reading all these posts i see ppl talkin about different kinds of engines which i know nothing about. I have 01 prelude se and I was wondering what kind of engine i got or how i can find this out. What's the difference betweeen h22 and h23 and other different engines?
thanx
Old Nov 14, 2001 | 05:06 PM
Greyout's Avatar
Default Re: engine question (pr0digy1)
there is no such thing as a 2001 prelude SE.
if yours is a 2001, regardless of trim level, you have the H22A4 engine.
Old Nov 14, 2001 | 05:44 PM
Gabe's Avatar
Default Re: engine question (JDM LUDE)
No you're incorrect on that. There is a Canadian model called the SE which is basically the SH without ATTS (or the base model with the SH rims, spoiler, etc.).
You have an H22A4 and the engine code should be on the block directly to the left of the header heat shield.
Gabe
[Modified by Gabe, 8:45 PM 11/14/2001]
Old Nov 14, 2001 | 06:26 PM
Greyout's Avatar
Default Re: engine question (Gabe)
hmmm.... learn somethin' every day...
Old Nov 14, 2001 | 06:46 PM
illusion's Avatar
you do..
also, the h23 is only on the 4th gen preludes. 92-96
Old Nov 14, 2001 | 07:40 PM
ELUD THS's Avatar
New User
Default Re: engine question (illusion)
heres the breakdown.
h22a - jdm dohc vtec
h22a4 -- 5th generation lude dohc vtec
h23- 92-96 NON VTEC ~ KEY WORD NON VTEC
Old Nov 14, 2001 | 08:07 PM
Mike95lude's Avatar
Default Re: engine question (ELUD THS)
you missed one.
h22a1 - usdm OBDI engine (dohc vtec)
Old Nov 14, 2001 | 08:28 PM
ELUD THS's Avatar
New User
Default Re: engine question (Mike95lude)
oh ya , i forgot the 92- 96 us h22a1 dohc vtec the imfamous "si"
Old Nov 14, 2001 | 09:56 PM
pr0digy1's Avatar
New User
so which engine is the best one?
what are advantages or drawbacks of the different engines?
Old Nov 14, 2001 | 10:39 PM
laughinxxx's Avatar
New User
JDM H22a<--- OBD?, 220 hp.
H22a1(92-95)<----OBD 1, 190 hp.
H22a4<----OBD 2, 200hp
Old Nov 15, 2001 | 08:10 AM
mr2's Avatar
mr2
so am I..
Old Nov 15, 2001 | 08:18 AM
Honda318dx's Avatar
Default Re: engine question (white eg)
Another great post! Go AWAY!
so am I..
Old Nov 15, 2001 | 09:18 AM
Greyout's Avatar
Default Re: engine question (laughin2.2)
the JDM H22A is not 220 HP. Thats the Type S motor.
The JDM h22A has 200PS, or 206HP
as far as the H22a1 vs h22a4, although they are rated differently at the crank, the H22A1 seems to put just as much, if not a few more, HP down at the wheels
[Modified by JDM LUDE, 6:20 PM 11/15/2001]
Old Nov 15, 2001 | 10:17 AM
Mike95lude's Avatar
it does
OBDII sucks
4doorH22's Avatar
Anyone know what gives the JDM motors a slightly higher rated output?
I think the extra power of the H22A4 over the H22A1 is strictly due to the exhaust manifold design, a moot point since almost everyone gets an aftermarket header.
So what's with the JDMs? Is it just better aspiration or compression ratio or cam profile or what?
Old Nov 15, 2001 | 11:46 AM
LudeLC's Avatar
New User
Default Re: engine question (4doorH22)
not a moot point because you get smaller if any gains out of a header upgrade on the a4
Old Nov 15, 2001 | 11:59 AM
4doorH22's Avatar
Default Re: engine question (LudeLC)
Well that's if you're measuring gains instead of maximum HP.
But of course, most important is area under the curve.
Old Nov 15, 2001 | 04:35 PM
Gabe's Avatar
Well there are two JDM versions of the H22 in the prelude. One is almost exactally the same as the US version and has the same hp rating. The other motor is the Type S/SiR S-Spec version which has higher comp., more radical cams, slightly larger tB, mild p&p, etc.
Gabe
Old Nov 15, 2001 | 11:32 PM
ELUD THS's Avatar
New User
all i got to say is that OBDII really sux . no matter what you really do to your car you got to remeber that h22A4 there OBDII sensors on there can really restrict on what you do. also you go to remeber to be naturally aspirated, honda does a fantastic job with the engine for maximum gain of hp from the factory. so what ever bolt on you do to the car will not be like a domestic where you put an intake and get 100 hp. i myself for instance have a 5th gen lude with AEM cam gears, Greddy EVO cat back. AEM cai, dc sports ss headers , with all the basic bolt ons i havnet gained as much HP as i wanted to when i dynoed. at the most i assume 15 hp. all i got to say is that with the JDM type S , like "GABE" said, there comp is adjusted different, the main focus stands on the cams, plus you got to remeber that JAPAN does not have emmision laws << besides engine swapping at 40,000>
but they have there headers bored out larger without a catalyac converter., plus, the throttle body i do believe is bored out to 70mm. thats why there dispalcement is 220 hp. not the amwerican h22a4 which is 200 hp. dam i wish i had a type "s"
accord03coupe
Aug 24, 2006 07:36 PM
specv5150
Nov 11, 2003 01:54 PM
SM Polishing
Dec 18, 2002 06:55 PM
Davanca
Aug 7, 2002 12:24 PM
prekitt
Jul 7, 2001 07:41 PM
