engine dying when warmed up....
Old Jun 15, 2008 | 10:13 AM
pprowler6's Avatar
Default engine dying when warmed up....
ok guys ill try and explain this the best that i can. Last friday i took my car out for the first time in about a week. car started right up no problems and i was drving it for about 10 min when all of the sudden it seemed like it was losing all of its power and it was trying to shut off. I kept it in a low gear and gave it a lot of gas so it wouldnt shut off. Came up to a red light and the tach was jumping like crazy. i put it in gear when the light turned green gave it gas and it just shut off. Try and start it a couple times with no luck. Leave it there over night go back the next day and it starts up( really rough start) Drive it to my mechanic casue i didnt want to mess with it and it barely makes it there when it does the same thing. It seemed once the car warmed up it would start to have theses problems. My mechanic looked at and calls me to tell me that it is my ecu. He says when the car is cold it runs in a "open loop mode" and when it warms up it runs in "closed loop mode" which i guess means what fuel maps it uses i dunno. But he says that its ecu is done for and i need to get a new one to see if thats the only problem. Does this seem like i reasonable problem? I dont see how something like that can go bad all of the sudden. My buddy was telling me there could be a chance thats its the o2 sensor and considering i replaced mine a couple weeks ago when i replaced my headers and downpipe with and old o2 sensor i could see that being the problem. Sorry if that didnt make much sense. Any insight would be great. thanks guys
Old Jun 15, 2008 | 06:08 PM
vtecb18c's Avatar
Default Re: engine dying when warmed up.... (pprowler6)
yea its prob the ecu...is the car stock? if you have a fpr check the pressure and make sure your not unloading too much fuel
Old Jun 16, 2008 | 07:49 AM
pprowler6's Avatar
Default Re: engine dying when warmed up.... (vtecb18c)
yea i checked the distributor, timing , spark, ignitor...all that good stuff everythign checked out.i mean the car is relatively stock just intake, headers, exhaust, no a/c or p/s but other than that stock.my buddy has an extra p28 laying around i think ill look for a stock h23 basemap a burn a chip and see if that works before i buy another ecu
Old Jun 16, 2008 | 07:54 AM
4WSi_guy's Avatar
when it dies do you have spark? do you have fuel? these are the things you need to check when it dies. To me it sounds like a main relay...pull the relay and check for burn rings on the circuit board. The relay is under your dash by the steering column
http://techauto.te.funpic.org/mainrelay.php
Old Jun 16, 2008 | 08:11 AM
pprowler6's Avatar
Default Re: engine dying when warmed up.... (4WSi_guy)
i actually just replaced the main relay a couple months back...i will give it another look though. If the main relay were bad why would it start back up after the engine cools down?
Old Jun 16, 2008 | 09:51 AM
vtecb18c's Avatar
yea a chipped 28 will work fine
Old Jun 16, 2008 | 11:05 AM
4WSi_guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pprowler6 &raquo;</TD></TR><TR><TD CLASS="quote">why would it start back up after the engine cools down?</TD></TR></TABLE>
My accord did that, I would stop at the gas station and it would not start back up until it was cooled down. I guess the relay gets hot as well from the high resistance because of the bad solder. I could take the relay out and take it inside in the air conditioning and then plug it back in and it would start. then it would get hot again and wouldnt start. Had a local shop re-solder the original and I havent had any problems.
Good luck!!
Old Jun 16, 2008 | 11:24 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pprowler6 &raquo;</TD></TR><TR><TD CLASS="quote">i actually just replaced the main relay a couple months back...i will give it another look though. If the main relay were bad why would it start back up after the engine cools down?</TD></TR></TABLE>
Because the soldering on the main relay expands when when it gets hot, this gives
you a bad connection. When it cools down the soldering contracts and gives you a good connection again.
Old Jun 27, 2008 | 06:47 AM
jdmeg6978's Avatar
Im having the same exact problem with my 93 SI h23 stock automatic
did you ever figured out what was causing the car to die after warm up? could this really be the main relay?
mkeacura
Sep 17, 2013 06:17 AM
TigerLy
Jul 25, 2009 12:07 PM
djwest24
Oct 24, 2005 07:44 PM
Mike95lude
Oct 11, 2005 01:00 PM
Ri5e
Apr 3, 2002 10:44 PM
