EL Conversion question
Old Feb 26, 2007 | 03:15 PM
H22TurboNos's Avatar
Default EL Conversion question
does anyone know or what they used to splice the wires and plug into the gauge?
i have a 93 prelude and going to do the analog to el conversion, but since the clips are different wanted to know what you guys used to stick the wires in there. images or some form of description will be much appreciated!
Old Feb 26, 2007 | 03:18 PM
M2B4's Avatar
Default Re: EL Conversion question (H22TurboNos)
did u change the dash harness or are u using ur old harness?
Old Feb 26, 2007 | 03:54 PM
bb_one's Avatar
The easiest way to do the conversion would be to use the dash harness for the EL gauges. That way, the conversion is practically plug and play. You'll also need the inverter box for the gauge cluster as well.
Old Feb 26, 2007 | 05:12 PM
Default Re: EL Conversion question (M2B4)
planning to just splice it, im having a real hard time findind a dash harness replacement
Old Feb 26, 2007 | 09:15 PM
Honda_Fanatic's Avatar
there is a write-up here on HT somewhere. Search
Old Feb 26, 2007 | 10:47 PM
Default Re: EL Conversion question (Honda_Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">there is a write-up here on HT somewhere. Search</TD></TR></TABLE>
i read the write-up it still doesnt answer my question
Old Feb 26, 2007 | 10:49 PM
ninja 6's Avatar
I got lucky I guess
What happened was when I bought the EL gauge cluster the harness was cut. So the gauges had the clips intact. I just used what I had to work with and spliced/soldered.
Otherwise, i would have tried to find some wire insulators to plug each wire into each corresponding wire on the gauge. Be creative.
Old Feb 27, 2007 | 06:41 AM
BTW I have 2 complete EL guage setups I can sell.
Old Feb 27, 2007 | 06:42 AM
rawNArsxS's Avatar
imed!!!
Old Feb 27, 2007 | 10:27 AM
MrLude1's Avatar
How much would you let one go for? I've been wanting to convert to the digital dash since I swapped in the H22, I'm near Chicago btw...
Old Feb 27, 2007 | 01:01 PM
boosted93h22lude's Avatar
Default Re: EL Conversion question (MrLude1)
the best way to do the conversion is to get the cluster and the harness together, i did it the hard way with half of the el harness and the analog harness and got it work with alot of splicing and soldering but when i turned the headlights on the cluster would go black so i ended up buying the harness off a 95 and now it works perfect, hey brian its mike from cpc if you get it let me know i can help ya put it in.
Old Feb 27, 2007 | 04:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">BTW I have 2 complete EL guage setups I can sell.</TD></TR></TABLE>
sent you a pm
Old Feb 27, 2007 | 07:07 PM
clemsoncb7's Avatar
Haha, not to threadjack, but I also have a complete EL gauge setup to sell, let me know!
Max
Old Feb 27, 2007 | 08:16 PM
rawNArsxS's Avatar
HELL YEA FINALLY GETTIN SOME EL GUAGES!!!!
Old Feb 28, 2007 | 12:22 PM
Default Re: EL Conversion question (boostfedbb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostfedbb &raquo;</TD></TR><TR><TD CLASS="quote">Haha, not to threadjack, but I also have a complete EL gauge setup to sell, let me know!
Max</TD></TR></TABLE>
im looking for anyone who has a harness, if the gauges are complete with the harness then im willing to buy it off you
Old Mar 5, 2007 | 10:39 AM
rawNArsxS's Avatar
guages came in today, ive been seachin but nothin is comin up, any1 got the actual write up? i got one that i bookmarked a while ago but the link isnt workin. ive used "el guages", "el guage swap", "el guage conversion", conveting to el guages" nothin comes up for any of them. the only thing i have is a writeup from vancouver preludeonline and all it really says is wut each harness consists of. any help is greatly appreciated
Old Mar 5, 2007 | 11:23 AM
pinecone's Avatar
Default Re: EL Conversion question (rawNAprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rawNAprelude &raquo;</TD></TR><TR><TD CLASS="quote">guages came in today, ive been seachin but nothin is comin up, any1 got the actual write up? i got one that i bookmarked a while ago but the link isnt workin. ive used "el guages", "el guage swap", "el guage conversion", conveting to el guages" nothin comes up for any of them. the only thing i have is a writeup from vancouver preludeonline and all it really says is wut each harness consists of. any help is greatly appreciated</TD></TR></TABLE>
It would help if you spelled "gauges" right in your search.
Old Mar 5, 2007 | 12:16 PM
rawNArsxS's Avatar
Default Re: EL Conversion question (pinecone)
yea i noticed that too after i was lookin, but i tried both ways n still nothin.
No Results Found
Your search for el gauge conversion returned no results.
Please try different search criteria or a different data set.
» No Results Found
Your search for converting to EL gauges returned no results.
The following words are too short or too common and were not included in your search: to, el.
Old Mar 5, 2007 | 01:43 PM
pinecone's Avatar
I had no problems finding anything. Make sure you also hit archive, b/c that is where all the info is.
This might help:
https://honda-tech.com/zerothread?id=1528977
Old Mar 5, 2007 | 01:48 PM
rawNArsxS's Avatar
i had hit archive too...idk y nothin came up for me though. i tried about 10 different ways of el gauges, el conversion, el dash , electroluminicent...none worked for me
rawNArsxS's Avatar
thanks though, i appreciate it...im gonna check it out n see how it goes
Old Mar 5, 2007 | 05:38 PM
ninja 6's Avatar
wussy
Old Mar 5, 2007 | 09:39 PM
Lil. Cease's Avatar
ok so i installed mine 2 days ago n well the rpm needle is stuck n my speedo needle is waaay off. any1 got an extra cluster? or know how i can fix this thanx.
Old Mar 6, 2007 | 09:54 AM
rawNArsxS's Avatar
Default Re: EL Conversion question (ap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap &raquo;</TD></TR><TR><TD CLASS="quote">wussy</TD></TR></TABLE>
who r u callin a "wussy"
Old Mar 6, 2007 | 11:23 AM
M2B4's Avatar
j/w did any of yall who replaced the harness did cruise control still work?
