ecu technical question...
ok 96 vtec ecu runs peak and hold injectors.... will it run on a 97plus lude with saturated injectors? Is it not the resistor pack which determines this or the ecu itself? Can I run an OBD2 96 ecu on a 97+ lude?
Modified by 96SR-V at 6:04 AM 4/15/2003
Yes, I think a 96 ecu will run a 97+ prelude, straight plug-in. Yes an OBD1 P72 ecu can run low resistance injectors with a resistor pack, and can run a 97+ prelude with an adapter harness and chip.
prelude9999
Oct 18, 2004 11:49 AM
