ECU code 41- primary oxygen snensor heater
Old May 25, 2005 | 02:34 PM
Eucalyptus lude's Avatar
Default ECU code 41- primary oxygen snensor heater
My lude just pulled an ecu code 41. this is the primary oxygen sensor heater. I just replaced by old primary o2 sensor with a bosch o2 sensor about 2 months ago. Help me out here guys.
Old May 25, 2005 | 03:27 PM
md23vtec's Avatar
Default Re: ECU code 41- primary oxygen snensor heater (Eucalyptus lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eucalyptus lude &raquo;</TD></TR><TR><TD CLASS="quote">My lude just pulled an ecu code 41. this is the primary oxygen sensor heater. I just replaced by old primary o2 sensor with a <U>bosch</U> o2 sensor about 2 months ago. Help me out here guys. </TD></TR></TABLE>
That could be your problem. Im just a firm beliver in stock honda parts but maybe its just me.
Old May 25, 2005 | 05:31 PM
Gabus's Avatar
Nothing wrong with a bosch O2, as far as I know. Did you use the generic one that requires making wire connections? check your connections.
Old May 25, 2005 | 06:01 PM
prylwd's Avatar
At work we ran into a similar problem (it was on a Ford Ranger though) it ended up being a strip fuse but it took like 3 full days for someone to figure it out.
Was it a universal O2 sensor?
Old May 25, 2005 | 07:05 PM
Default Re: (prylwd)
Yes it was a universal oxygen sensor. I belive that the connections are fine becasue it did it personally with my friend who has lots of electrical experiance. Im still gonna jack her up and take a look at the wiring again. In case the wiring is fine, what else could it be?
Old May 26, 2005 | 08:48 AM
Default Re: (Eucalyptus lude)
BUMP ^^^^^^^
Old May 26, 2005 | 08:54 AM
mafia's Avatar
make sure every thing is connected, if still having a problem... burn your cheak engie light
Old May 26, 2005 | 09:32 AM
98TypeSH's Avatar
Default Re: (mafia)
i had the same problem. Replace the primary o2 with an aftermarket OEM replacement and not 3 months later i had to replace it with a real OEM honda replacement. boy that wasnt cheap.
Old May 29, 2005 | 01:43 PM
Default Re: (98TypeSH)
The problem is that im really in debt. Is it ok to keep driving like this if i just reset the code?
Old May 30, 2005 | 10:37 PM
Tonight my battery light kept coming on , and then wouild randomly disappear after a while. I tried to see if the battery contacts were good, tapped the alternator, and restarted the car multiple times, only to see the same problem again. Im thoruoghly convinced that something is wrong and i cant find it. I spend 300 on a new alternator, new battery, and i need to track this damn problem down soon.
Old May 30, 2005 | 10:39 PM
SoOHiGH's Avatar
Default Re: ECU code 41- primary oxygen snensor heater (md23vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec &raquo;</TD></TR><TR><TD CLASS="quote">
That could be your problem. Im just a firm beliver in stock honda parts but maybe its just me.</TD></TR></TABLE>
theres nothing wrong with those parts. i bought a O2 sensor from Autozone 2 years ago and its still working. forgot what brand though.
Old May 31, 2005 | 09:54 AM
Im gonna go pull my ECU right now and try to check all the conections going into it. If any more opinions are floating around, please post em .
Old May 31, 2005 | 07:30 PM
Alright, so i spent 3 hours checking everytinhg. i pulled the ECU, checked all the connections. They all appered to be fine. i cleaned the plug that goes into the alternator, cleaned the battery terminals that are actaully brand new, checked all the fuses, checked most of the wiring i could check. After all this, the problem is still there. I cant drive the car now, so this really blows
Old May 31, 2005 | 07:36 PM
Altilude's Avatar
voltage regulator? off the top of my head - let me check helms heh.
Old May 31, 2005 | 07:40 PM
Altilude's Avatar
Default Re: ECU code 41- primary oxygen snensor heater (Altilude)
also - in the meantime - how is/was your belt tension to the alt? possibility of slippage? creating a no-charge situation?
Old May 31, 2005 | 07:50 PM
Altilude's Avatar
don't spose you got a helm's eh? there is a good explanation on 23-105 and 23-106 on how to go about troubleshooting it. with possible outcomes -
1. light (obviously your light works! hehe)
2. fuse 23 (underdash fuse box)
3. opens in certain wires (somewhat unlikely but you never know)
4. voltage reg. took a *****.
of course it's a lot more detailed.. i could try and help you more, if none of this helps and you dont' have a helms
Old May 31, 2005 | 09:31 PM
well altilude, i unfortunatelly dont have a helms cuz none round her carries it. Provbly time to buy one online. I check ed the tension on the alternator, and its very tight , spins fine and turns the pulley well. I checke dthe fuze box under the hood, nad in the wheel well, and all the fuzes seem to be fine. I thought hte the voltage regualtor was built into the alternator but i might be wrong here. If it isnt the voltage regualator, then by god it must be an open wire somewhere. That **** would be sooo hard to find tho. OH damn i hope thats not it. Thanks again guys.
Old May 31, 2005 | 09:57 PM
I just went on a middle-of the night tedt to see how the lude is doing and all is crap. I started the car and then pulled the negative batt. terminal off of the battery and the car instantly died on me. What would that mean?
Old Jun 2, 2005 | 08:18 PM
Altilude's Avatar
1. turn the ignition switch on
___does the charging system light come on (batt light) ---- no? - other problem
(yes)
2. Start the engine.
___does the charging system light go off (i assume your problem)
(no)
3. turn the ignition switch off
4. Disconnect the 4-P connector from the alternator
5. turn the ignition switch on
6 Does the charging system light come on?
(yes disconnect the abs control unit, the 4ws control unit, and the integrated control unit as applicable. if the charging system light stays on repair the short to ground in the wht/blue wire.
(no wht/blu wire is OK, perferm alt/regulator test.
7. turn the ignition switch off
8. check the no. 23 fuse (15A) in the underdash fuse/relay box.
is the fuse OK?
(no replace the fuse
(yes
9. disconnect the 4-p connector from the alternator
10. turn the ignition switch on
11. check for voltage at the IG (blk/yel wire) terminal of the 4-p connectotr
___is there battery voltage?
(no repair open in the blk/yel wire
(yes ground the wht/blu wire at the L terminal of the 4-p connector
___does the charging system light come on?
(no check for a blown charging system light bulb. if the bulb is ok, repair the open in the wht/blu wire.
(yes replace the voltage reg.
4/P connector (t, and T are plastic not pins).
_ t _
I T I first I on this line is L (wht/blu) , second I on this line is IG (blk/yel).
p.s. BUMP for curious if this is solved/how (:
Old Jun 3, 2005 | 01:42 PM
PrettyLude's Avatar
Default Re: (Gabus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gabus &raquo;</TD></TR><TR><TD CLASS="quote">Nothing wrong with a bosch O2, as far as I know. Did you use the generic one that requires making wire connections? check your connections.</TD></TR></TABLE>
check your wiring, or try switching ur wires around
924drb20
Dec 14, 2010 10:36 AM
JoshJosephKeith
May 4, 2009 04:38 PM
SpoonCivicSir20
10
Mar 29, 2009 10:14 PM
claytonsmith
10
May 16, 2006 12:01 PM
ShittyGSR
Jul 17, 2004 05:59 PM
