ECU?!?!??!?!?!
Old Oct 2, 2002 | 08:22 AM
oinkus's Avatar
Default ECU?!?!??!?!?!
is a 95 gsr's ecu compatible with a 97-up prelude????
what aobut 2000 gsr's?????
do i need anything to make them work??
Old Oct 2, 2002 | 11:24 AM
prelude1897's Avatar
Default Re: ECU?!?!??!?!?! (oinkus)
I don't think integra ECUs will even work on a prelude. Expecially 97+ They have the immobilzer system, plus different ratios for gearing, mph, rpms
Old Oct 2, 2002 | 11:29 AM
satan_srv's Avatar
Default Re: ECU?!?!??!?!?! (prelude1897)
Okay again, you're not correct.
GS-R ecus are compatible with preludes, but only 96+ OBDII ECUs would plug right into a 97+ prelude.
To do an OBDI (94-95 GSR) swap you need an adapter cable. But yes the pinouts for the DOHC VTEC are the same per OBD generation. GS-R on an H22a will run lean, but they are best for reprogramming, so I recommend a reprogrammed P72 (GS-R) for a prelude.
You would lose the immobilizer.
[Modified by satan_srv, 3:30 PM 10/2/2002]
Old Oct 2, 2002 | 12:55 PM
oinkus's Avatar
Default Re: ECU?!?!??!?!?! (satan_srv)
thanks satan_srv.. i jsut my hands on a 99 gsr ecu from my friend for free
thanks for the info
Old Oct 2, 2002 | 01:39 PM
Buckkaaaa!!'s Avatar
New User
check out importreview.com for a dyno of the P72 on a OBD2 lude...
Old Oct 2, 2002 | 02:26 PM
satan_srv's Avatar
Default Re: ECU?!?!??!?!?! (preludeboy)
I hope you have a V-AFC...Dyno with a wideband 02
Old Oct 2, 2002 | 03:06 PM
oinkus's Avatar
ok but i'm not gonna install it anytime soon........my car is still stock....
yellow_R_dragon
Aug 3, 2006 12:53 PM
Slava.
Apr 21, 2004 11:13 AM
CamGriffin
Apr 13, 2004 08:06 AM
chrisir19
Jan 11, 2004 05:50 AM
hondaZvic
Jun 29, 2002 06:06 PM
