ebrake?
Old Jun 2, 2010 | 03:11 PM
cheapo23's Avatar
Default ebrake?
how do you adjust the e brake on a 93 prelude?
Old Jun 2, 2010 | 03:46 PM
Kronn 98SH's Avatar
Default Re: ebrake?
Helm's manual, Chapter 19, Page 5.
Old Jun 2, 2010 | 03:48 PM
cheapo23's Avatar
Default Re: ebrake?
if i had one i wouldnt be on here asking
Old Jun 2, 2010 | 03:53 PM
Kronn 98SH's Avatar
Default Re: ebrake?
That's cute. Go download it. Try using that big, fat Search button.
Old Jun 2, 2010 | 06:08 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: ebrake?
ADJUSTMENT
See Figures 2, 3, 4, 5 and 6
If the rear brakes have been serviced or replaced, start the engine and press the brake pedal several times to adjust the brakes before adjusting the parking brake cable. Incorrectly adjusted rear brakes (disc or drum) will affect the function of the parking brake mechanism.
1. Raise and safely support the vehicle on jackstands.
2. On rear disc brake equipped vehicles, make sure the lever of the rear brake caliper contacts the brake caliper pin.
3. On drum brake equipped vehicles, make sure the rear brakes are properly adjusted.
4. Pull the parking brake lever up 1 notch.
5. Remove the access cover at the rear of the console or remove the rear seat ashtray. On some models, it may be necessary to remove the center console to gain access to the adjusting nut. Tighten the adjusting nut until the rear wheels drag slightly when turned.
6. Release the parking brake lever and check that the rear wheels do not drag when turned. (Don't confuse a light brushing noise with drag; you'll feel the drag.) Readjust if necessary.
7. With the equalizer properly adjusted, the parking brake should be fully applied when the parking brake lever is pulled up 7-11 clicks on 1984-89 Accord and 1984-91 Prelude or 4-8 clicks on 1990-95 Accords and 1992-95 Preludes.
For a civic but gives you another angle
Old Jun 2, 2010 | 06:29 PM
Kronn 98SH's Avatar
Default Re: ebrake?
Why the spoon-feeding? He had his answer.
Old Jun 2, 2010 | 08:08 PM
cheapo23's Avatar
Default Re: ebrake?
hey kronn thanks for the help fool
Old Jun 2, 2010 | 09:28 PM
Kronn 98SH's Avatar
Default Re: ebrake?
You're welcome, dolt.
CrAzyGsR101
Nov 22, 2019 05:18 AM
civicekgsr99
Suspension & Brakes
Nov 7, 2008 01:46 PM
globy123
Aug 15, 2007 05:27 PM
espm1000
Sep 14, 2006 09:47 AM
mickey513
Oct 2, 2003 04:35 AM
