Distributor Troubles..
Old Jun 15, 2010 | 03:47 PM
shaylude's Avatar
Default Distributor Troubles..
Ok, car seemed to somewhat "bog down" so I pulled the dributor cap off and cleaned the corrosion that was inside (with a small wire brush and blew it out with an air compressor) and put it back on. Now the car will only crank over but not completely fire up.
The rotor spins when cranked but their is no spark.
Jdm H22a, internal coil
I have searched the countless distributor threads and have had no luck.
..any suggestions?
Old Jun 15, 2010 | 05:24 PM
shaylude's Avatar
Default Re: Distributor Troubles..
Any help on how to test the ignition coil would be awesome
Old Jun 15, 2010 | 07:00 PM
shaylude's Avatar
their is a spring toward the bottom of the cap.
is their a carbon point or anything that goes on the end of the spring?
Old Jun 16, 2010 | 12:47 AM
niterider96cord's Avatar
There should be the internal ignition coil touching that spring. Sounds like you took to much off the contact points. Try new cap & rotor.
Old Jun 16, 2010 | 05:05 AM
shaylude's Avatar
I very lightly took the discoloration off the points.. lets hope I didn't..
I have a new rotor that I was going to put on, but even after unscrewing the bolt to remove the rotor it wont move at all.
Old Jun 16, 2010 | 06:26 AM
emgjsdk1's Avatar
did you take the dizzy completely off?
if you did make sure you didnt spin the rotor piece that goes into the cam, if you spun it 180 degrees, your car wont start.
if you did take it off then pull it again and spin it 180 and try it, if not then dont spin it.
Old Jun 16, 2010 | 07:39 AM
shaylude's Avatar
No this is the crazy thing,
All we did was take the cap off.
Try to remove rotor (wouldn't come off)
Put cap back on, won't start..
I have a huge show I've been working toward Saturday, its going to be frustrating if I can't make it...
Old Jun 16, 2010 | 07:54 AM
ilikehonda's Avatar
the dist will only go on one way. you cant spin it 180 degrees....if you do it wont go on.
sounds like you took a little too much off the points/rotor.
to check the coil grab a test light, ground it, touch the test light to the spring on the end of the coil and have someone crank it over..if it lights up then your coil is working.
the rotor can be a pita to get off. just keep pulling it will eventually come off.
Old Jun 16, 2010 | 08:39 AM
tofast4uh22's Avatar
^^^^ not true the dizzy can be installed 180 out. it does not slide in as easy but it can go in and can damage things.
Old Jun 16, 2010 | 08:55 AM
Mikey3000's Avatar
did you take the spark plug wires off the cap when you did this? if so, did you put them back in the correct order?
Old Jun 16, 2010 | 11:39 AM
Not sure which car you have but most hondas have a bolt holding on to the rotor. It may have been pointing down at the time, therefor unnoticable. If you did remove that bolt use a flat head and sledge hammer to get the rotor off.
Old Jun 16, 2010 | 01:57 PM
ilikehonda's Avatar
you would have to shove that ****ing thing so hard that it should throw a red flag. what on earth would it damage even if you did. the car just wouldnt start.....
if you have to push with much force to get the dizzy in you are doing it wrong.
Old Jun 16, 2010 | 06:10 PM
shaylude's Avatar
New Cap
New Rotor
Check the coil 1.4omhs so its good
correct voltage going into the distributor
still no spark..
need information on checking the ignition coil..
this is just crazy, drove the car into the garage.
went to drive out and now this.. i've gotta be running for the meet..
Old Jun 16, 2010 | 06:19 PM
boostmyda's Avatar
try replacing the ignitor in the dizzy (the thing with 4 wires going into it?)
just replaced mine..... fixed my no-start who knows...
I also had to replace the coil though.
Old Jun 17, 2010 | 06:46 AM
shaylude's Avatar
I know the 99-01 civic distibutor cap works for the jdm h22a.
does the coil as well?
and information on removing and testing the ICM would be great.
Old Jun 17, 2010 | 08:19 AM
boostmyda's Avatar
autozone and o'riellys might be able to test the ICM also for free
LadyKiller1998
Aug 17, 2017 05:42 AM
dave n
Nov 20, 2013 10:41 AM
IndySporty
Jul 27, 2010 01:19 AM
menappi
Jun 26, 2006 05:37 PM
lsvtec_hatchback
May 22, 2006 07:43 PM
