dented trunk pan
Old May 2, 2006 | 02:29 PM
shutta's Avatar
Default dented trunk pan
I figured i'd let some 4th gen guys know that it may not be a great sport to jack the rear up from. It's reccomended to jack the car upn from the rear center tow hook, but months ago when I thought my jack waslosing pressure, it was actually my trunk being dented in which lead to a hole being exposed just under the threaded rod goes to hold the spare wheel down. I bondoed it, but when i loked at it yesterday it was raised up somehow and probably leaking.. i'm probably going to clean everything out, and epoxy from the inside and outside of the trunk and maybe use some subberized undercoating on the outside too to prevent eater leaks... just a heads up guys, jack up from the rear cross-member instead unless you want to wind up in my boat. I have no idea why honda thought that was a tough enough spot...
Old May 2, 2006 | 05:28 PM
helicopter201's Avatar
Default Re: dented trunk pan (shutta)
my 93 si has 4 recommended jack spots, right underneath the sideskirts...fits the jack perfectly
Old May 2, 2006 | 06:16 PM
iLude's Avatar
Default Re: dented trunk pan (helicopter201)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by helicopter201 &raquo;</TD></TR><TR><TD CLASS="quote">my 93 si has 4 recommended jack spots, right underneath the sideskirts...fits the jack perfectly</TD></TR></TABLE>
That doesn't work when you need both wheels off the ground at once...
Thanks for the tip, OP. I've always used that spot for my rear jacking point, as it says in the FSM. Anyone else have problems like this?
Old May 2, 2006 | 06:56 PM
Moto_340's Avatar
yeah
Old May 3, 2006 | 12:38 PM
FINEBB6's Avatar
ramps brother ramps
Old May 3, 2006 | 01:31 PM
shutta's Avatar
Default Re: dented trunk pan (1FINEBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1FINEBB6 &raquo;</TD></TR><TR><TD CLASS="quote">ramps brother ramps</TD></TR></TABLE>
to work on brakes? no thanks. I couldn't have used the sideskirt jack points either because of my wwrs sideskirts
Old May 3, 2006 | 04:07 PM
soundbomber's Avatar
so you're saying your trunk was dented from when you jacked up the car from the rear tow hook?
Old May 3, 2006 | 05:37 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: dented trunk pan (soundbomber)
thats how i took it too...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">so you're saying your trunk was dented from when you jacked up the car from the rear tow hook?</TD></TR></TABLE>
Old May 4, 2006 | 01:56 PM
shutta's Avatar
yeah, my manual said that was a legit jack point..
Old May 5, 2006 | 01:44 PM
TheWalrus's Avatar
do you jack the car up and then lower it onto jackstands or just put the jackstands under there while the jack holds the weight? ive never heard of this happening before...which makes me think your hook is defective...or it was something you did wrong.......
Old May 5, 2006 | 05:45 PM
shutta's Avatar
it happened sooner than I coudl slide in teh jack stands. basically while i was jacking it up, it was slowly caving in. I thought the jack was losing pressure somewhere so i turnerd the handle to the right but it already ws all the way, my tunk was open, and that's when I noticed a huge lump in it
psyloki
Sep 28, 2006 01:05 PM
BlazingSoul
Nov 17, 2005 07:47 PM
HankYee
Oct 16, 2005 12:56 PM
ekcivic9
Sep 30, 2005 06:55 PM
mugenracer
Aug 26, 2003 09:51 PM
