Cylinder Position Sensor???
K - found my service connector - pulled a 9 and a 23
9 - Cylinder Position Sensor - Intermittent Interruption/ No Signal
23 - Knock Sensor Circuit Malfunction
All new to me... can anyone help?
THANKS
THANKS
the knock sensor code is fairly easy to try and fix, just amke sure that your wires are all good, and make sure that the knock sensor did not get screwed up during your swap
the CYP sensor is in the distributor., check all the wiring there and you should reset the codes and see if it throws them agian/
Thanks for the info!
I'll check it all out.
I noticed your sig... I have my old 92 charcoal cloth interior. I found leather out of a 96 and swapped. The seats are in good condition. Let me know if you are interested.
mdjplay@mac.com
mdjplay@mac.com
T_Rex
27
Feb 12, 2003 07:41 PM
