crazy irratic idle
ok guys i need help, i just got an act clutch and fidanza flywheel installed, slave cylinder, rear main seal... i start driving home from the shop and my ******* idle is going up and down and sounding like ****, its normal idle is 700, but now its like 1100-1400, going up and down up and down... and my check engine light keeps coming on and off.. wtf is going on?
my check engine light comes on and off, at various times... and the surging/irratic idle isnt all the time either, its only occausionally... but my Warmed up idle is about 300 rpm higher than it should be.... either way, when the check engine light comes on again, im gonna read the codes... ill let you guys know what it says
all is fixed, apparently one of the vacuum hoses was lose or unhooked, and my oil filter was loose too, heh.. i was leaking tons of oil.. those bastards!.. but all is well now
