cooling system question
Old Jul 7, 2005 | 11:02 AM
staticrex's Avatar
Default cooling system question
I replaced my radiator a week or so ago and after buttoning it all up I proceded to fill the radiator. I basically dumped in new coolant until it reached the top, I then squeezed the top radiator tube and the coolant level went down, so I turned the heat to full blast and started the car with the cap off. I opened the bleed screw and when it started streaming out I closed it up. About 5 minutes later the car reached 1/2 on the temp gauge, about 15 more minutes went by and no cooling fans turned on. So I let it go on for another 5 minutes and nothing.
<U>I know that the bottom radiator tube is not full, and I am afraid to drive it. I did fill the overflow tank to the fill mark, so my question is if I am driving will fluid be pulled from the overflow tank to fill the system? </U>
I think the only way the fans will come on is if I drive it, but Iam worried about if the fans don't come on, and rish overheating.
I did take out the thermostat and checked in on my stove, and it opened up perfectly.
So I am also thinking could the temp sensor in the head be bad, and how would I check?
Old Jul 7, 2005 | 11:16 AM
eMpAtHy's Avatar
Default Re: cooling system question (staticrex)
what i do is i leave the cap off..let it bubble off for a while..
Old Jul 8, 2005 | 06:01 AM
staticrex's Avatar
Default Re: cooling system question (eMpAtHy)
ok, any other information as to if the system will fill itself up using the overflow tank?
Old Jul 8, 2005 | 06:16 AM
Ministry's Avatar
as long as you aren't overheating don't worry about it. sitting at idle, my H22 takes literally 20 minutes or so to turn on the fan. it freaked me out at first
if your bottom hose really doesn't have fluid there is something seriously wrong - there are no valves or anything that would prevent it from filling up. it should fill when you fill the radiator. here comes captain obvious: did you take out the plastic plugs that probably came in your radiator? (assuming you got it new)
Old Jul 8, 2005 | 06:19 AM
staticrex's Avatar
Default Re: cooling system question (dreamer)
Yeah I took them out.
I just don't think that the bottom lower radiator hose will fill up close to the thermostat.
ahhhh who knows I will just drive the som bitch and see what happens.
Old Jul 8, 2005 | 06:26 AM
Ministry's Avatar
eh? lower radiator hose close to the thermostat? on an H22? I confused
Old Jul 8, 2005 | 10:47 AM
staticrex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreamer &raquo;</TD></TR><TR><TD CLASS="quote">eh? lower radiator hose close to the thermostat? on an H22? I confused</TD></TR></TABLE>
Ok the lower radiator hose, that goes from the bottom of the radiator and swoops up towards the TB. It connects to the thermostat housing. That is the hose I am talking about.
Yes on a H22.
Old Jul 8, 2005 | 11:58 AM
Ministry's Avatar
LOL at me
my bad I must have Mitsubishi on the brain I was just helping my friend with his eclipse.
anyway is it overheating? fan cut on?
Old Jul 11, 2005 | 06:07 AM
staticrex's Avatar
Well I drove it about 14 miles today, it was about 98 degrees outside. Did not overheat but the cooling fan didn't come on either? When I turn on the a/c both the fans come on, so I know it works. But I am wondering if the temp sensor is faulty, or the thermostat is now bad. Just checked it about 4 days ago.
Old Jul 11, 2005 | 03:35 PM
H22A_civic's Avatar
you need to take the top hose off the radiator and pour the fluid into that hose to go into the block until it overflows out of the hose then strap it back on the radiator! if you don't do that the thermostat will not open up and your fan will not come on.
fuglybutruns
Jul 28, 2015 07:50 PM
S_F
15
Sep 13, 2010 01:50 PM
DC4 ENTHUSIAST
Oct 30, 2008 08:50 PM
DelSolMarine
Oct 31, 2006 03:19 PM
92VtecTeggy
Jun 20, 2003 08:13 AM
