Collector mod
I've seen a lot of posts about modifying the collector on a header but i'm not sure exactly what the collector is even after reading many posts about it. Is the collector on the header or the downpipe?
Re: Collector mod (Htwentytwoforme)
its where the 4 pipes come together, bro
here you go dude. this is a dc header. i heard good things about the greddy header with this mod.
https://i4.photobucket.com/albums/y1...sx/dc_mod1.jpg |
Re: (ludeR917)
so you have to cut the flanges off both pieces, the header and the downpipe where they meet and put bigger ones on?
Re: (ludeR917)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludeR917 »</TD></TR><TR><TD CLASS="quote">here you go dude. this is a dc header. i heard good things about the greddy header with this mod.
https://i4.photobucket.com/albums/y1...sx/dc_mod1.jpg</TD></TR></TABLE> What if you want to keep the flex pipe? So all you have to change is the downpipe, nothing needs to be done to the header? Modified by Htwentytwoforme at 10:37 PM 8/18/2005 |
Re: (Htwentytwoforme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Htwentytwoforme »</TD></TR><TR><TD CLASS="quote">What if you want to keep the flex pipe? So all you have to change is the downpipe, nothing needs to be done to the header?
Modified by Htwentytwoforme at 10:37 PM 8/18/2005</TD></TR></TABLE> flex pipe also comes in diff. sizes, so you would need a 2.5in ID flex pipe which can be found at the K teller site. |
Re: (foshizllmynizl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foshizllmynizl »</TD></TR><TR><TD CLASS="quote">flex pipe also comes in diff. sizes, so you would need a 2.5in ID flex pipe which can be found at the K teller site.</TD></TR></TABLE>
So do i need to bring the flex pipe and flanges to the muffler shop or will they already have all the necessary parts? And the 3 bolt flanges they have on the kteller site, those are the exact same ones that come on the DC downpipe and will bolt right up to my exhaust? |
http://www.freepichosting.com/Thumbs.../8/200/150.jpg
This was done with parts from Autozone. $8 in parts to be exact. Its TIG welded and the welding looks better in person than the pics. In person the welding is perfect. You can clearly see the size difference with the two collectors next to each other in this pic. |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Htwentytwoforme »</TD></TR><TR><TD CLASS="quote">So do i need to bring the flex pipe and flanges to the muffler shop or will they already have all the necessary parts? And the 3 bolt flanges they have on the kteller site, those are the exact same ones that come on the DC downpipe and will bolt right up to my exhaust?</TD></TR></TABLE>
bump https://honda-tech.com/forums/images/smilies/emthup.gif |
So do i need to bring the flex pipe and flanges to the muffler shop or will they already have all the necessary parts? And the 3 bolt flanges they have on the kteller site, those are the exact same ones that come on the DC downpipe and will bolt right up to my exhaust?</TD></TR></TABLE> that depends on the shop, but most do. call and ask. If the flanges aren't right, they can chop one off and weld a new one on in a few seconds. |
Re: (ludeR917)
https://i4.photobucket.com/albums/y1...sx/dc_mod1.jpg</TD></TR></TABLE> What are the disadvantages, if any, to ditching the flex pipe when doing this mod? |
What are the disadvantages, if any, to ditching the flex pipe when doing this mod?</TD></TR></TABLE> it doesn't matter. as long as you have either the spring bolts on your flanges or a flex pipe, you'll be fine. Its just to keep your exhaust from breaking if it gets hit. |
| All times are GMT -8. The time now is 09:24 PM. |
