code 9 wont go away
Old Dec 29, 2006 | 08:13 AM
nonvteclude's Avatar
Default code 9 wont go away
im getting a code 9 cylinder possition sensor. i have tested the sensor swapped to a new distributor and the code just wont go away. what else should i check?
Old Dec 29, 2006 | 08:21 AM
98vtec's Avatar
moderator emeritus
Default Re: code 9 wont go away (nonvteclude)
do you have a helms?
go to hondahookup.com and download the section you need and following the troubleshooting steps.
Old Dec 29, 2006 | 08:27 AM
Default Re: code 9 wont go away (B.Rabbit)
ya i have a helms and went step by step through it and cannot get that code to go away, and i know its not the ecu cuz i have a new working one and even swapped with another one that wasn't throwing any codes from another lude.
Old Dec 29, 2006 | 08:34 AM
98vtec's Avatar
moderator emeritus
have you unwound the harness and checked for openings in the loom?
Old Dec 29, 2006 | 09:22 AM
no ill check that, the harnes has been removed alot in the past so could be it
werdling
Aug 4, 2007 05:20 AM
tekstyle
Apr 17, 2004 11:50 AM
SpoonPL
Sep 27, 2002 07:39 PM
White Lightnin
Jun 28, 2002 09:15 AM
wreckedagain
May 12, 2002 06:43 PM
