code 45 system too rich or lean
Old Aug 28, 2007 | 08:32 AM
charlie0801's Avatar
Default code 45 system too rich or lean
so i got this code out of my prelude and the symptoms are the following:
bogging at low rpm <2000
and some rare backfire at the same rpm
i already ran some injector cleaner through the gas with no changes... anyone else have any solutions?
Old Aug 28, 2007 | 11:33 AM
JasonST's Avatar
Default Re: code 45 system too rich or lean (charlie0801)
Check ur spark plugs, they'll tell u if ur running rich or lean. Knowing if u're running rich or lean will help determine what to check for next.
Old Aug 28, 2007 | 11:41 AM
i guess running rich is black crap on them but what about lean?
this is for a 5th gen base model lude just so no one asks
Old Aug 28, 2007 | 04:27 PM
Default Re: (charlie0801)
ok so took the plugs out and took some pics so here they are from cylinder 1 to 4
basiclt they all black with some white crap on the little arm part
Old Aug 28, 2007 | 04:50 PM
mgags7's Avatar
they look pretty good dude, that doesn't seem to me to be the problem. slightly lean I would say
I would check to make sure the egr valve isn't stuck open by buildup and that the map sensor is soundly connected, not leaking, etc.
Old Aug 28, 2007 | 05:20 PM
got a pic of the location of said components?
Old Aug 28, 2007 | 05:59 PM
mgags7's Avatar
get a manual for your car, that should be the first step in solving any problem.
Old Sep 8, 2007 | 01:01 PM
k well i cleaned out the EGR valve this morning and no change. the valve is working fine. so now im leaning towards getting all the ignition components changed (rotor cap and wires)
anyone else have anhy input?.
Old Sep 8, 2007 | 03:57 PM
DCxMagus's Avatar
looks those plugs are rich in the lower rpms and getting leaner in VTEC
I never got a code but when I had my bogging issue it turned out that my cap and rotor had probably never been changed in the 95000 miles the previous owner had it and it all worn away changed that with plugs and wires for good measure and the car was a whole different car.
how does the power feel in the rest of the power band?
do you have any mods?
try and give a lot more info to narrow the problem.
Old Sep 8, 2007 | 06:19 PM
mgags7's Avatar
just fyi, that code normally comes when the o2 sensor is on its way out.
Old Sep 8, 2007 | 08:07 PM
power 3500 and up feels as it should (based on what ive seen so far) and ive changed the 02 sensor with one from an accord i had to lenghten the wires) and no change.
turboeg831
May 10, 2008 03:31 PM
Baron55
Jul 2, 2007 02:32 AM
Mik3
Jan 26, 2006 06:35 AM
B00ST2nR
Oct 19, 2002 02:36 PM
B00ST2nR
Oct 19, 2002 01:30 PM
