clutch problems
alright well they delted my last post but anyway.... my clutch is being really weird, when i push it in it stays in and doesnt pop back and when the car is on i cant put it in gear! my friend at a shop said its the slave cylinder. it was also out of clutch fluid. but i filled that up and it helped a little bit. its still really f*ed up. doesnt anyone have a tutorial on changing the slave cylinder if it is that because dobbs wanted to charge 200 bucks. thanks
If it was out of clutch fluid, you need to refill with dot 3 brake fluid and bleed the slave. That will fix your problem.
Don't change the slave cylinder.......just bleed it. If you ran out of fluid, the vehicle sucked in air......air in your lines will make it act like that.
ok get a friend to help
1.pedal all the way up
2.open bleeder
3.push down pedal, hold down
4. close bleeder
5. pedal all the way up
6.never let the fluid in the resivoir all the way down of else air gets in and you start all over again.
if the bleeder is open when you pull the pedal up, air gets sucked in.
That is a quote from StevoBA8 ......and yes that is the proper procedure.
2.open bleeder
4. close bleeder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax »</TD></TR><TR><TD CLASS="quote">Fill it, open bleeder, have a friend push down pedal, close bleeder, take foot off pedal, add fluid if required. Repeat as necessary</TD></TR></TABLE>
There ya Go!
There ya Go!
obviously your leaking clutch fluid. what i did was fill up the clutch fluid and jus pumped the clutch pedal. it begin to get better but still acting weird. so i looked under where my clutch pedal is and my clutch slave cylinder was leaking. changed that up. bleed the clutch with fresh clutch fluid and fixed my problem!
NFrank89
Transmission & Drivetrain
Nov 30, 2009 07:27 PM
redline7
Feb 17, 2008 12:24 PM
sniperslayer
17
Nov 5, 2005 06:29 PM
