clutch
Old Dec 18, 2005 | 04:28 PM
CivicSiDriver02's Avatar
Default clutch
After my car warms up the the clutch pedal gets about 3x as stiff and will fully engauge at almost full travel. Also if I hold the clutch in at a stop light or something for about 15 seconds or more(rather than shifting into neutral), as soon as the pedal come off the floor the car will start to creep forward but again will not engauge untill it is almost fully out. After a little bit of highway driving the clutch will start to slip to the point were I will basically have to pull over and let it cool. I replaced the slave cylinder about a month ago, the master is about a year old, and I am not leaking any fluid. The clutch is a spec stage 2 kelvar unit with about 10k on it with a fidanza aluminum flywheel. Anyone have any suggestions to fix my lude? thanks
Old Dec 18, 2005 | 04:37 PM
The Weather Man's Avatar
Seems like you have air in your system. Air bubles or something. Bleed the slave.
Old Dec 18, 2005 | 04:49 PM
Default Re: (TheKINGPin)
Thats what I thought too but I have bled it out like 5 times now and get a solid stream of fluid and no air.
Old Dec 18, 2005 | 05:11 PM
BB6racer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKINGPin &raquo;</TD></TR><TR><TD CLASS="quote">Seems like you have air in your system. Air bubles or something. Bleed the slave. </TD></TR></TABLE>
air bubbles would make the pedal soft and stick to the floor. my clutch used to give me trouble when i used it for a long time (like highway driving or auto-x). replaced the clutch and the problem went away. what brand was the clutch? maybe the clutch is just that stiff.
Old Dec 19, 2005 | 06:36 PM
Default Re: (BB6racer)
The clutch is a stage 2 kevlar from spec clutch. When I first got it I never noticed that it would progressively get stiff the more you drove it. It only came about over the last 6k miles (installed for about 12k). The clutch is a little bit stiffer than stock which is as I would have expected but I didn't expect that it would start to slip once it got hot. I am hoping that it is not worn out due to street driving when it may be better suited to the track. Also is it possible that the clutch dampener could be bad? I don't know if the heating of the fluid would cause the seals in the dampener to expand and in turn allow fluid to slip by them. Any more input would be appreciated. Thanks.
Mike banX
Transmission & Drivetrain
Feb 16, 2011 06:58 PM
Mike banX
10
Feb 16, 2011 01:12 PM
blacklabel14
Feb 3, 2011 12:32 PM
xxgriffonxx2
Apr 28, 2010 10:18 AM
EgGriff
Jan 9, 2006 08:40 AM
